Thread: 08 gxp
Results 1 to 10 of 10
  1. #1 08 gxp
    Apr 2013
    Blanchardville WI
    Has anyone ran into this problem...the tach seems to jump around 300 to 500 rpms in overdrive at 55 to 60. I does get pretty violent at times when lugging it. Any hints or clues? Any help would be appreciated.
  2. #2 Re: 08 gxp
    Dec 2012
    Where 4T65E's were born
    By lugging it you mean giving it gas? It' probably the torque converter applying, then dis-engaging rapidly due to a bad torque converter solenoid. Those usually go bad around like 160k+
    Sold.
  3. #3 Re: 08 gxp
    Apr 2013
    Blanchardville WI
    by lugging it I mean hardly on the throttle...so do you think its the torque converter it self or is there a sensor or solenoid on the transmission case. Is it hard to replace?
  4. #4 Re: 08 gxp
    Dec 2012
    Well first how many miles? I don't think I've ever seen one go bad before 140k, and it usually happens when attempting to disengage, when giving it gas. Does it always to it? Is the check engine light on? Do you have a way to scan for codes?
    Sold.
  5. #5 Re: 08 gxp
    Arizona
    Are you sure its not a combination of dod and ****ed up engine mounts you're feeling. Also what do you have done to the car
  6. #6 Re: 08 gxp
    Pennsylvania, USA
    Mine is acting up since about 85k, it certainly can happen earlier. I have to go in through the side cover this week because of how irritating it's become.
  7. #7 Re: 08 gxp
    Dec 2012
    Yours pulses when downshifting (unlocking under acceleration) right?
    Sold.
  8. #8 Re: 08 gxp
    Apr 2013
    Blanchardville WI
    Well thats it....the tranny puked! drove it 30 miles and acted great! Got in it and drove 1 mile got to a stop sign pushed the gas and the tach went to 3000 and didnt move! Pushed it 3 blocks and parked it for the weekend! Dont want to but prob gonna trade it off! Bummer!
  9. #9 Re: 08 gxp
    Dec 2012
    Did you ever check the trans fluid level and color?
    Sold.
  10. #10 Re: 08 gxp
    Warranty?
