Hello I have 2000 GP 3.8 non SC, here is the ID 610brb and w4s2d what others will interchange? will basically any 2000 pontiac 3.8 non SC work?
a site i was on showed all these numbers under the same unit??? 9BCB, 2BCB, 9THB, 9KAB, 0BRB, 0BCB, 1BCB. will all these interchange??
Pretty much anything from 1998-2002 NON S/C transmission will work.
Aslong as its from a grand prix or regal. The bonnevilles and monte carlo did sometimes get different gear ratio's of a 3.05 in those years.
The real only difference from 98-99 will be the trans cooler lines I believe, they are different in how they connect to the radiator. Not a hard fix.
i do not see a MN7 M15 on the trunk tag..
ok , ty i was hoping that was the answer
i was looking a the AZ site.. they have the numbers above all on the same trans part number.. from 2000 up to 02
seems the 98 and 99 are different.
