Thread: Gear indicator on shifter sometimes off, dash ok
Results 1 to 5 of 5
  1. #1 Gear indicator on shifter sometimes off, dash ok
    Oct 2013
    WI
    I'm having an issue where sometimes I have got move the shifter around a few times so it correctly displays the gear at the shifter, though it's always correct on the dash, ie I can shift into drive and it can show neutral on console and drive on the dash, and I'm definitely not in neutral. Seems a little unusual since I'd think the indicator at the shifter should be a direct connection, as opposed to the dash which would need a cable and could get off. Any tips or suggestions before I dig into it?
  2. #2 Re: Gear indicator on shifter sometimes off, dash ok
    Dec 2008
    Lawndale, CA
    What year?
  3. #3 Re: Gear indicator on shifter sometimes off, dash ok
    Oct 2013
    WI
    Sorry, 1999 GTP
  4. #4 Re: Gear indicator on shifter sometimes off, dash ok
    Oct 2013
    WI
    Yesterday it stopped moving altogether - I just took it apart and found the issue. The little plastic piece that clips to the side of the shifter that the indicator rod slides through had fallen off (reinstalled it in the pic). On closer inspection it has a crack in it, epoxy is currently curing...
  5. #5 Re: Gear indicator on shifter sometimes off, dash ok
    Dec 2008
    Lawndale, CA
    Glad to hear it was a simple fix.
  1. shifter indicator
    By tyler sharp78 in forum Audio, Security & Visual Electronics
    Last Post: 10-16-2013, 03:38 PM
  2. Changing Shifter Indicator Bulb
    By KoldAsIce in forum Visual/Body Modifications
    Last Post: 06-04-2013, 12:17 AM
  3. Gear Indicator Always On?
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2011, 10:40 AM
  4. Gear Indicator on 99 gt
    By bigboibbp in forum Audio, Security & Visual Electronics
    Last Post: 10-18-2009, 11:38 AM
