Thread: 97 Grand Prix GTP Tranny shifts into 2nd gear late
Results 1 to 3 of 3
  1. #1 97 Grand Prix GTP Tranny shifts into 2nd gear late
    Hey guys, problem.... Ive got a 97 Grand Prix GTP. The Tranny shifts into 2nd gear late. Right around 40 - 55 MPH. Alot of time if you are constantly accelerating you have to back off to allow it to shift into 2nd gear. Runs great though. Any ideas guys? Thanks in advance
  2. #2 Re: 97 Grand Prix GTP Tranny shifts into 2nd gear late
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Sounds like it may be slipping pretty bad but because it is an electronically controlled transmission it must be properly diagnosed with a scan tool to know exactly what is going on. With a scan tool you will be able to view when the pcm commands each shift. If the pcm is not commanding the shift and the reason it is late then there is a reason for it. If the pcm IS commanding the shift and it is not happening then the trans is likely slipping and possibly in need of replacement.
  3. #3 Re: 97 Grand Prix GTP Tranny shifts into 2nd gear late
    Thanks Trannyman95. That sounds like my next step then. Was hoping for a different fix, but knew that was probably it. Will take it in to get a diagnosis. Will report back here with my findings.
  1. my grand prix
    By grandprix0429 in forum Off Topic Discussion
    Last Post: 06-22-2010, 08:07 AM
  2. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
  3. 92 Gran Prix Tranny
    By dvorak in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-05-2008, 12:31 AM
  4. Another Late Intro
    By Kel04GTP in forum Introductions/Noob Questions
    Last Post: 01-04-2008, 01:25 PM
