Thread: EP Differential??
Results 1 to 19 of 19
  1. #1 EP Differential??
    Moore, Oklahoma
    Anyone here run one of these? I remember 3 or 4 guys from ClubGP have great luck with them unlike the Intense ones. I'm curious to hear more results on these. The GMR is the best no doubt, but you're talking $1,800 too.
    I've been looking at these for awhile now. I honestly don't think the stock diff will ever been good enough for me. I've seen at least 5 "built" 4T65-HD trans at the track that couldn't do a 2 wheel peel. Personally, I'd be pissed having a $3,000 tranny that can't even let me do a two wheel peel. I don't want to feel this way when I get my built tranny installed.
    Shawn W. Larsen
    Oklahoma
    I dont know about them, but Modbug recommended these guys when I talked to them about a tranny eons ago:
    Phantom Grip - Limited Slip Differential. Get A Grip!
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    I installed an EP diff in one of my transmissions about a year and a half ago. The guys name on cgp is Tweeter. I know he had some other issues with his engine and never really heard if he made it to the track but it was an XPZ setup and ran pretty strong. This diff is the only option I leave people with, BUT I will NOT warranty the trans with any limited slip diff installed. EP also gives you 100% ZERO warranty on these diffs, comforting ehh? And as an added bonus you have to send in your diff first and I waited over 3 weeks to get it back when I was told one week turnaround. I liked the way it looked better than the Intense diffs at the time, but it is still the same concept and is still going to cause undo wear during every day driving which is going to put debris in the pan. Even guys with limited slip diffs dont always get two wheel burnouts. It really boils down to this and this is what I tell people.... If this is a LIMITED use car, ie weekends or strip only and not many miles per year then you will probably be OK with an LSD, but again even they are no promise to two wheel burnouts.
    Oklahoma
    Quote Originally Posted by Trannyman95 View Post
    Ah, yeah, very good point. Where is all that clutch material going to end up.
    Fort Wayne, IN
    It is not the clutch material that bothers me, that is soft material. It is the large metal plates in the center with springs pushing them against the side gears..... Any time you turn a corner, go around a slight curve on the highway, etc, those gears spin at different speeds which causes those plates to wear into the side gears and create metal debris. Without getting really creative there is no way around this. This is why the Torsen or GM racing diff is the best way to go, but yes it has a very hefty price tag to go with it. Those diffs use worm gears that will bind when wheel spin occurs. There is nothing to wear and no undo stress going around corners.
    GrandPrix Junkie
    Saraland Alabama
    no metal shavings is definatly a good thing
  7. #7 Re: EP Differential??
    SE Level Member hydro1110's Avatar
    Mechanicsville VA
    Ive been thru three LSD so far and will not put another one back in my tranny unless I get the GM one. I ran the CYA diffs and all three took out my tranny each time. Ive since put a stock diff back in and almost always get a two wheel burnout. Ive raced the car for 2 yrs now and can pull 1.7 60's with it. I recently pulled the stocker out to check it and found that I broke the cotter pin that holds the shaft in place. I replaced the cotter pin and have no issues with it now.
  8. #8 Re: EP Differential??
    Moore, Oklahoma
    Thanks for the info Trannyman. Guess i'll hold off. Have you seen a GMR diff Trannyman? What are your opinions on it? I wish it didn't cost so damn much...
    Shawn W. Larsen
  9. #9 Re: EP Differential??
    Fort Wayne, IN
    I havent seen one personally but I think they were noted to still fail under high power with hard launches and track passes but i cant confirm this as i dont know. The very hefty price tag sure makes them a turnoff though! This style diff is the way to go for an attempt at getting two wheel traction though you often get this with a stock diff and a proper burnout.
  10. #10 Re: EP Differential??
    I live here. UR LOSN's Avatar
    Rockford, IL
    Trannyman- where would one pic up a GMR?
  11. #11 Re: EP Differential??
    Donating Users jmak gtx2's Avatar
    Mableton, GA 30126
    I have a EP LSD in my car. He is local for me in Atlanta. I do a lot of long distance driving along with going to work in town. But little track time Dyno on the car is 210HP I have had one diff in for over 20,000 miles and when we replaced it so he could upgrade to a newer version I saw very little wear. The newer version I have had in for about 10,000 miles with no trouble so far. As of now I love the Diff because I can get into traffic faster altho I some times spin in loose gravel.
  12. #12 Re: EP Differential??
    SE Level Member Gearhead43's Avatar
    ATL, GA
    Shawn,
    If you remember the TGP and what happened to it.... Best to stay away from EP... Like Trannyman said... Jeff offers NO warranty on his stuff...
    1989 Turbo Grand Prix Clone
    2000 Daytona Pace Car Replica #1134/2000
  13. #13 Re: EP Differential??
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Very interesting, what are all the LSD diff options out there? What style is the intense diff, and what about zzp? What do they use?
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  14. #14 Re: EP Differential??
    Fort Wayne, IN
    Your options are basically the Torsen/GM Racing diff, Intense, EP, Phantom Grip, C-Ya racing Mike Dye diff, and Im sure there are others. Lost known knowledge to me of ZZP was they still use STOCK diffs as they are the most reliable, yes you read that right even in the 9 second cars. The Thrasher/C-ya diff, Intense diff, EP and Phantom grip diff all modify the stock diff to use clutches behind the side gears. As I mentioned earlier in this post the EP is my favored diff of the clutch style but dont like the NO warranty offering with it and the wait time, so plan ahead if this is a must have item. The Intense diff is a gamble, after hundreds of bad Gen 2 diffs that they sold I dont know anyone who was brave enough to try a Gen 3 diff but I know they are out there. The GMR diff is very expensive, around $1500 and up but is the best option in my eyes if you really want to use a limited slip differential.
  15. #15 Re: EP Differential??
    Moore, Oklahoma
    I wonder how the Intense Stage 3 LSD is better if at all?
    Shawn W. Larsen
  16. #16 Re: EP Differential??
    Rockford, IL
    have a friend that had the Gen II grenade at the strip usung street tires. I have heard nothing but good about the GenIII's. honestly...I havent heard of one that blew up. I am undecided between the GenIII or the GMR......
  17. #17 Re: EP Differential??
    New Salem, ND
    After reading that zzp uses a stock diff in the TTGT I think I will stick with the stock one when I build my tranny and if I ever decide I need LSD in the future I can install one then.
  18. #18 Re: EP Differential??
    SE Level Member GTP Mark's Avatar
    Dec 2019
    Canada
    Anyone still use the EP differential? Has it changed much since 2008? lol
  19. #19 Re: EP Differential??
    Kemmerer, Wyoming
    I bought one about five years ago and really liked it. held up great to about 350 hp. He is still making them and can be found on facebook or through his website.
