Thread: Lazy shifting
Results 1 to 20 of 23
  1. #1 Lazy shifting
    Aug 2013
    Ontario
    Hey I have a 2007 GP GT and the last few cold days I've been having some shifting troubles. The first couple shifts will be lazy and long and when it finally shifts it sort of slams into the gear. I had planned on doing a shift kit but I want to make sure I don't have bigger problems first. It only happens between first and second. Any ideas?
  2. #2 Re: Lazy shifting
    I'd do a filter and fluid change with a bottle of Lucas and a shift kit
  3. #3 Re: Lazy shifting
    From the description, it sounds pressure soleniod. Which Smutty suggested the best way around doing that soleniod.
  4. #4 Re: Lazy shifting
    Aug 2013
    Ontario
    I just did a fluid mad filter change less than 5000km ago. I wanted to do a shift kit but didn't want to wait any longer before changing the fluid. Would this kit do what I need?
    http://www.superiortransmission.com/...Page.cfm?ID=41
  5. #5 Re: Lazy shifting
    Yes and no. The kit you were being referenced to was the transgo kit. Most of the parts in that kit go into the accumulator which is accessible from the pan. That kit you linked is a pull the side cover and redo the valvebody (likely need special tools) kit.
  6. #6 Re: Lazy shifting
    Aug 2011
    'Merica
  7. #7 Re: Lazy shifting
    Joe..he's a bit north of us...shipping would likely be more than the kit.
    That's something I'll never understand. (knock knock)
    Recipient: "Eh.. hello post guy"
    Postguy: "Eh.. I have this small package for you, that'll be $35 right now please"
    Recipient: "Oh, I am happy to pay that, I live in Canada"
  8. #8 Re: Lazy shifting
    Aug 2011
    'Merica
    I didn't look at the op's location....
  9. #9 Re: Lazy shifting
    Km's gave it away to me.
  10. #10 Re: Lazy shifting
    Aug 2011
    'Merica
    You are correct sir....I have trouble reading since I am from Southeast Ohio
  11. #11 Re: Lazy shifting
    Always watch for 90-100 degree thermostat temp, km's or the use of an "u" where you wouldn't use it, like colour. Dead give aways my sheep loving buddy.
  12. #12 Re: Lazy shifting
    Aug 2011
    'Merica
    I like pigs, goats and chickens too......
  13. #13 Re: Lazy shifting
    Aug 2013
    Ontario
    Shipping on that kit isn't too bad, only $19 but duty and customs might kill me. To buy that kit locally is $150 if you can believe it.
  14. #14 Re: Lazy shifting
    Aug 2011
    'Merica
    That sucks
  15. #15 Re: Lazy shifting
    You probably don't want to hear that I buy it locally for $42 w/o tax? Sorry.. I have hosted meets and the amount fixes to cars etc and the 4 days in the states limits etc.. you know how that goes.
  16. #16 Re: Lazy shifting
    Dec 2012
    Where 4T65E's were born
    To me that's a lot, since we don't usually pay anything but what it says on the ebay page.
    You say it only happens in the 1-2 shift? Never 2-3 or slow lockup? I'm no expert but it may not be pressure related if only 1 shift is affected. Could it maybe be that the 1-2 piston in the accumulator is slightly binding? Maybe the seal is torn or the bore has a groove or something? If so, when doing the shift kit, you will find out and be able to replace parts if needed at that time.
    Sold.
  17. #17 Re: Lazy shifting
    Aug 2013
    Ontario
    Haha I wish I could get it for $42, i would have put it in when the fluid was changed.
    The transmission shop I use seems to think it could just be time for a rebuild but because it happens infrequently it's hard for them to diagnose. It didn't do it this morning. The car also has an Overkill tune with the 05 PCM.
  18. #18 Re: Lazy shifting
    Aug 2013
    Ontario
    Transgo kit on order and a bottle of Lucas is in it for the time being.
  19. #19 Re: Lazy shifting
    Dec 2012
    Quote Originally Posted by savage93 View Post
    As long as you're past 100k miles, ANY issue means it's time for a rebuilt to shops. I'm at 110k and I was getting slow shifts, and eventually banging shifts (max adapt). They would have recommended a full rebuild. A fix was 1 new PCS($32) and it should be good for another 50k miles easy.
    Sold.
  20. #20 Re: Lazy shifting
    Aug 2013
    Ontario
    Well I got my transgo shift kit finally and I'm going to install it this week. One question before I do, has anyone heard of matching up one of the longer spacers and using two long spacers on third and using the extra short spacer in the position on second where transgo doesn't provide a spacer?
  1. To Lazy
    By Hidenface in forum Introductions/Noob Questions
    Last Post: 11-02-2012, 07:04 PM
  2. finally got off my lazy as's
    By gtcoup in forum Off Topic Discussion
    Last Post: 08-21-2011, 08:52 PM
  3. Rap Real Lazy
    By LowRidinCrew in forum Off Topic Discussion
    Last Post: 06-01-2011, 03:19 PM
  4. Lazy Boost
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2011, 08:35 PM
  5. Greetings from The Lazy R !!!
    By thelazyr in forum Introductions/Noob Questions
    Last Post: 08-27-2010, 06:21 PM
