Thread: Car won't start moving from a stop until 3k rpm
Results 1 to 7 of 7
  1. #1 Car won't start moving from a stop until 3k rpm
    Nov 2011
    Omaha, NE
    Pretty much all the info my sister gave me. She has an 01 Impala with the 3.8. Funny thing is that I had the car last week and the trans was shifting amazingly and now apparently it doesnt wasnt to even start moving until she hits 3k. So is this a torque converter issue? or is it something else?
  2. #2 Re: Car won't start moving from a stop until 3k rpm
    Dec 2012
    Where 4T65E's were born
    Tell her to do this when it's happening. If it won't go, keep your foot off the gas, and put the gear selector in 1 and see if it goes right away. Also I'm assuming if she put it in reverse it does the same thing? If it goes right away, or much sooner in 1 than D, the issue may be an input clutch piston not sealing properly.(putting it in 1 increases line pressure) It's a somewhat common issue on 4t65e's but it's so weird how I see it most on impalas when they're really all the same.
    Sold.
  3. #3 Re: Car won't start moving from a stop until 3k rpm
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    The emergency brake is off right?
    I know it sounds dumb, but I have seen this many times.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  4. #4 Re: Car won't start moving from a stop until 3k rpm
    Dec 2012
    You'd still be able to go if the parking brake is on, or at least you'd do a burnout.
    Sold.
  5. #5 Re: Car won't start moving from a stop until 3k rpm
    Nov 2011
    Omaha, NE
    I'll let her know. Apparently she says it is random
  6. #6 Re: Car won't start moving from a stop until 3k rpm
    And the Impala guys post much more about this than any other trans issue. Recently I've picked up 3-4 Impalas.. all trans swaps based on the piston.
  7. #7 Re: Car won't start moving from a stop until 3k rpm
    Dec 2012
    Yeah that's really odd. They are the same, besides the non hd, hd, and gxp version. Still mostly the same parts, and probably the exact same piston/seals.
    Sold.
  1. Probably Moving On
    By nault31 in forum General Grand Prix Discussion
    Last Post: 06-18-2012, 06:56 PM
  2. Moving to VA
    By fireprix in forum Southeast
    Last Post: 01-12-2012, 11:19 PM
  3. Moving on............
    By 07CrimsonGT in forum Introductions/Noob Questions
    Last Post: 04-14-2010, 09:56 PM
  4. Should I stop before I start?
    By GMDealer in forum General Tech Discussion
    Last Post: 04-03-2010, 12:55 AM
  5. Rough Start from stop....????
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2008, 06:56 PM
