Thread: Pressure Control Solenoid(EPC), TCC, 4th Clutch Hub Replacement in the Vehicle.
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 105
  1. #1 Pressure Control Solenoid(EPC), TCC, 4th Clutch Hub Replacement in the Vehicle.
    Dec 2012
    Where 4T65E's were born
    Well since I'm getting tired of having low trans line pressure after it warms up, I think I'm going to get in there and change the PCS myself. Before the shift kit, I was experiencing very slow shifts after it warmed up, and soon after Max Adapt set in causing all gears to slam, even torque converter lockup. The shift kit fixed those 1-3 shifts(and eliminated max adapt), but I want my lockup to be quick as well. I also just want my trans pressure to be correct, bottom line. Lower isn't good. I have looked up many posts on many different sites on how to replace it, most people say it's labor intensive but every explanation I see makes it seem fairly easy. I've dropped subframes a few inches and removed engine/trans mounts, I've removed ball joints to remove CV axles, I've done a trans fluid change and had the confidence to do a shift kit. So basically it doesn't seem like much of a hard job to me. I'll probably spend a day on it though being my first time. Any tips or advice before I order the part and replace it? Like:
    1. Anything else I should replace while I've got access to the valve body?
    • Side cover gasket?
    • TCC solenoid? (Part#: 77942)
    • Boost valve? (I have a boost valve from my TransGo shift kit btw)
    • 4th clutch hub? (Aftermarket(heat treated) #84860C)
    2. Any other things that are hard to do?
    3. As far as I know the pcs is visible and replaceable after the side cover is off. I know I have to remove the bolts on the P/S rack to drop the subframe.
    4. And how about parts? Should I just get an AcDelco part? It's part#: 10478146 for the 98-02 pcs. I found it for about $31 on amazon.
    Amazon.com: ACDelco 10478146 Pressure Control Solenoid: Automotive
    This forum shows in detail how to gain access to the side cover: GM 4T65E solenoid shift valve replacement TCC/PWM EPC 1-2 2-3
    Very thorough write-up on how to replace the 4th clutch hub: http://www.gmtruckhq.com/drivetrain/...rade-3517.html
    Answers to the numbered questions and input is appreciated.
    Sold.
  2. #2 Re: Pressure Control Solenoid Replacement
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    I would replace the 4th clutch hub and pump shaft while I'm in there.
    The only thing standing in your way is a few bolts. You don't even have to remove the valvebody. Remove the chain cover as an assembly.
  3. #3 Re: Pressure Control Solenoid Replacement
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    While you are in there I would change at least the TCC PWM sol along with the PC. I'd stick with gm or get a borg warner one. The side cover gasket is a tossup... Sometimes its fine if you reuse it, but it depends on the condition of it when you get it off.. I have one for sale if you do decide to go for it. ($30+shipping/fees) Original GM one. Boost valve would depend if you want to take the valve body off.. Pretty sure the clip that holds it in is on the back side of the vb. (check your instructions) Taking that off you have to worry about the checkballs dropping out and you would need spacer plate gaskets too. Guess it depends on how much you want to spend whether you get all the solenoids or just the PC/TCC. I usually don't do the shift solenoids myself. Hardest thing is getting the side cover out of the way once you get it off.. pry down really hard on the cradle... and it will be able to come out. The rack you need to remove the bolt on the drivers side, and loosen the PS one and pry the rack up so that you don't separate the intermediate steering shaft.. that coming apart is a bad thing. Hope that helps. LMK if you have any other questions.
  4. #4 Re: Pressure Control Solenoid Replacement
    I'd buy a EPC aka PCS, channel plate gaskets and a 4th clutch hub. Since you are an 02, unless it's been rebuilt...it's an automatic on the hub. Have 4 M6 x 1.00 about 70-130mm bolts on hand with the heads missing and edges rounded. These are your "alignment pins/channel P gasket holders" when the trans is on it's side.
    Beyond that, it's nothing too crazy. You are going to be half under a suspended drivetrain and it needs to be lowered a decent amount to get the side cover off. Once that's off though, it's relatively simple. Really, it's just the time to do it.
  5. #5 Re: Pressure Control Solenoid Replacement
    Lorain, OH
    If you do go that far, get the metal channel plate gaskets, most aftermarket suppliers can get them. Dave from TEP has them and is amazing to deal with, you can probably get all your parts from him. He ships quickly and I can't say enough of the customer service. I may have a 4th hub here too, I will look around if you are interested.
  6. #6 Re: Pressure Control Solenoid Replacement
    Dec 2012
    Quote Originally Posted by Twizted 1 View Post
    Really? If it's removed as an assembly I might as well change the shaft then. I'll add that to the "list".
    Quote Originally Posted by DJNight2k View Post
    Yes this helps. So, I'll change the TCC Solenoid as well. So that's that, the PCS, and the 4th gear hub. - Also gaskets for the VB? and possibly the side cover. I have heard as well that sometimes they rip when removed. I don't really want to disassemble the VB if that's what it takes to replace the boost valve. The directions show this http://img7.imageshack.us/img7/9305/38b2.jpg
    This is an original trans as far as I know. And would you recommend changing the TCC solenoid as well? I've experienced the torque converter unlock shake on other vehicles with the 4t65e but with 200k on it. If it's easy to replace while I'm there I'll do that. I'll make sure I get the channel plate gasket(s)?
    And with the bolts.. Is this needed as well? I can't use the bolts that go through the gasket to align it? Or a gasket adhesive spray or something. I'd have to see it to know what you mean
    Thanks for the help.
    Okay so there is more than one. I'll look it up on the website.
    As a reference:
    PCS http://www.amazon.com/ACDelco-104781...vglnk-c2477-20
    TCC http://www.amazon.com/gp/product/B00...A2QOROTAURQN0I
    Hardened 4th Clutch Shaft: http://www.amazon.com/4T65E-4th-Clut...eywords=84860C
    Channel plate gaskets - only found on TEP, 8th item: http://tripleedgeperformance.com/Kit...__Gaskets.html
    Side cover Gasket http://shop.advanceautoparts.com/web...rm=side+gasket
    Total: $105.26
    With side cover gasket: $137.05
    Shift Solenoids http://www.ebay.com/itm/4T65E-Transm...55786f&vxp=mtr
    Does the part list look good? Complete, correct parts, etc.
    Thanks for the help guys.
    Sold.
  7. #7 Re: Pressure Control Solenoid Replacement
    Jul 2013
    Summertown Tn
    Don't change the side cover gasket unless its ABSOLUTELY necessary.
    And if you do end up changing it, go get a GM gasket. Rubber with metal insert.
    Torque all of the side cover bolts to 18ft/lb except for the bottom four torx bolts. Torque them to 16. I haven't had 1 side cover to crack doing them this way.
    The valvebody and channel plate can be removed as an assembly and is easier to teardown once it's on a flat surface.
    I'll see if I can come across a diagram of which bolts to remove to do it this way.
  8. #8 Re: Pressure Control Solenoid Replacement
    Jul 2013
    Summertown Tn
  9. #9 Re: Pressure Control Solenoid Replacement
    Lorain, OH
    There are 2 bolt holes on the side cover with smaller holes (alignment holes) one on the lower left and one on the lower right. Tighten those first starting w the one on the right (rear of cover).
    Good diagram twizted 1.
    If i was going to take the channel plate off to do the 4th hub i would take off the valve body and do the boost valve while it was out and on a flat surface. Less chance of having to chase the check balls around. You would need new spacer plate gaskets or a new spacer plate with bonded gaskets on it (that's how they come from gm now). I probably have one of those too if you are interested. But that being said probably not totally necessary to change the boost valve if you don't want to deal with that.
  10. #10 Re: Pressure Control Solenoid Replacement
    Dec 2012
    I'm not sure how the diagram is telling me what bolts remove the VB as a complete assembly. Which bolts do and don't come out for that?
    Yeah I don't really want to do the boost valve, it's not completely necessary and would cost me a bit more in gaskets.
    Sold.
  11. #11 Re: Pressure Control Solenoid Replacement
    Jul 2013
    Summertown Tn
    I'll get you something better when I get home. It'll be a LOT better at explaining it.
  12. #12 Re: Pressure Control Solenoid Replacement
    Jul 2013
    Summertown Tn
    How's this. Remove all the yellow colored bolts.
    You'll have to remove this solenoid to get to the bolt underneath it.
    Be careful with this dam taking it out.
    The pump normally shears the end of the pump shaft off from wear, so I would replace it while your there if it looks like this.
  13. #13 Re: Pressure Control Solenoid Replacement
    Dec 2012
    Oh wow yes that's really helpful, thanks. Do you recommend changing the shift solenoids too? They're just as easy to get to but it doesn't seem to be as encouraged by some people. Like it's not as important.
    Sold.
  14. #14 Re: Pressure Control Solenoid Replacement
    Jul 2013
    Summertown Tn
    Nope, check every solenoid then replace the ones out of spec.
  15. #15 Re: Pressure Control Solenoid Replacement
    Dec 2012
    Alright. I'd hate to not order them and find out that the resistance is off, then wait a week for shipping. So I may just replace them anyway since they're $15 a piece. How often do they go bad?
    Sold.
  16. #16 Re: Pressure Control Solenoid Replacement
    Jul 2013
    Summertown Tn
    I haven't personally seen one bad. (Shift solenoid that is).
    If it's not acting up I would leave them alone. You may get a china solenoid that will start acting up when you install it. I would change the problem solenoids and leave the rest alone.
    I would however change the manifold solenoid.
  17. #17 Re: Pressure Control Solenoid Replacement
    Dec 2012
    The shift solenoids claimed to be oem. 4T65E Transmission 1 2 3 4 Shift Solenoid 2 Pieces GM 4T65 | eBay
    I can't find a non-aftermarket manifold solenoid on ebay/amazon though.
    Sold.
  18. #18 Re: Pressure Control Solenoid Replacement
    Jul 2013
    Summertown Tn
    Don't buy aftermarket.
  19. #19 Re: Pressure Control Solenoid Replacement
    Dec 2012
    Right. Non-aftermarket. I'll just stick with the parts: PCS, TCC Solenoid, Hardened 4th gear shaft, and channel plate gaskets. I will order them soon.
    Sold.
  20. #20 Re: Pressure Control Solenoid Replacement
    Jul 2013
    Summertown Tn
    Pick up a pump shaft while your at it.
    Its probably worn badly.
    And its a 4th clutch hub. Don't want you to order the wrong part.
  1. pressure control solenoid ?s
    By circa09 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-11-2011, 03:53 PM
  2. Pressure control solenoid?? HELP
    By gtpman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-14-2010, 08:56 AM
  3. Trans pressure control solenoid replacement
    By PrixGT in forum General Tech Discussion
    Last Post: 07-06-2010, 09:21 AM
  4. Pressure Control Solenoid?
    By Klutch in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-04-2009, 01:09 AM
