Thread: trans slipping out of gear leaking fluid
Results 1 to 13 of 13
  1. #1 trans slipping out of gear leaking fluid
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    So I had a mild slip when cold but today its slipping all the time and started leaking a lot of fluid and smoking while driving. How f'd am i?
  2. #2 Re: trans slipping out of gear leaking fluid
    low fluid will make it slip. top off the fluid if it stops slipping, find and fix the leak.
  3. #3 Re: trans slipping out of gear leaking fluid
    Find said leaks, fix leaks, replace loss fluid and see what happens.
    Then you'll have your answer.
  4. #4 Re: trans slipping out of gear leaking fluid
    Dec 2011
    Decatur
    Cracked differential
  5. #5 Re: trans slipping out of gear leaking fluid
    thats fixable. in car too.
  6. #6 Re: trans slipping out of gear leaking fluid
    Dec 2011
    Decatur
    But if my tranny was already slipping? I mean its a nice chunk missing out of the bottom.
  7. #7 Re: trans slipping out of gear leaking fluid
    well that being said a rebuild is in your future. sooner just happened vs later.
  8. #8 Re: trans slipping out of gear leaking fluid
    Dec 2011
    Decatur
    Figured. So what happened I mean I know what I did but what happen to make that happen
  9. #9 Re: trans slipping out of gear leaking fluid
    pretty sure a pin in the differential drops out of place, catches the cover and it breaks.
    billboost37 has posted some pics in the past.
  10. #10 Re: trans slipping out of gear leaking fluid
    Dec 2011
    Decatur
    Could i swap diffs and still be okay for a little bit? The trans temp didnt get over 185
  11. #11 Re: trans slipping out of gear leaking fluid
    Dec 2011
    Decatur
    is it worth hd swap? And if so does it change my gears from 3.29s to 2.93s? Does it require tuning if it doesnt change gear ratio?
  12. #12 Re: trans slipping out of gear leaking fluid
    Step one, fix known issues. Did you tear the diff in half and it was slipping, then it cracked the case?
    You aren't changing that gear ratio easily. That would require pulling the side cover.
  13. #13 Re: trans slipping out of gear leaking fluid
    Dec 2011
    Decatur
    Ok good cause I want the 3.29s. But is it worth upgrading to hd kit? Idk car has been slipping cold start up on take off normal driving but yesterday I was a dumbass pissed of and gave it some throttle and next thing I know I'm smoking get home look under the car and there's a chunk missing from the dif case.
  1. CV Axle Leaking trans fluid?
    By GP_Kid18 in forum Brakes/Suspension/Chassis
    Last Post: 01-26-2012, 05:15 AM
  2. 1st gear slipping
    By sgatins in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-09-2011, 11:12 AM
  3. Leaking Trans Fluid (by axel)
    By TDgrand in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-06-2010, 03:20 PM
  4. Leaking oil or trans fluid?
    By zildjian102 in forum General Tech Discussion
    Last Post: 10-30-2010, 02:17 PM
  5. 4th gear slipping
    By RickA in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-20-2010, 06:02 PM
