Thread: Question about transmission fluid
Results 1 to 15 of 15
  1. #1 Question about transmission fluid
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    I have a 98 GTP with 198k on it. I have no idea when or if the trans fluid has been changed. It looks very clear to me like too clear IMO. Anyways I am wanting to do a pan drop/drain and a filter change and I'm not sure if I should go with Dexron VI or if I'll be ok with Dexron III. I know they are backwards compatible but I wasnt sure if itll mess anything up if the previous owner put VI in it and I put III in. The cheapest I could find VI for is 40 dollars and thats using walmart brand fluid.
    I went NA when a whore left -$300 in my bank account.
  2. #2 Re: Question about transmission fluid
    Just run dexron 3, its cheaper.
    And thats what your dipstck says.
  3. #3 Re: Question about transmission fluid
    Jan 2012
    Indianapolis
    Alright. Thanks. I was just not clear on if it would mess the tranny up if its filled with dex VI right now and I went back to Dex III
  4. #4 Re: Question about transmission fluid
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    Mine was red/orange when I changed mine. Pan was somewhat dirty. Put dex vi in and still good about 10k miles later. This was around 70k miles and I have 80k now. But if you can, dex 3 would prolly give you a pier of mind apposed to switching to the newer dex 6. Lets just hope your trans isn't already falling apart lol
    1998 Grand Prix GTP Daytona - CAI, XP Cam, Iceman tune, Speed Daddy Headers, 3.2 in pulley, Ported blower, Al 103's, 3in Catless DP, Transgo "shift kit", No resonator to Magnaflow Mufflers. 93K Miles
  5. #5 Re: Question about transmission fluid
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    I'd probably stick to the dex III unless you were using a machine to flush all the fluid out of it, not that I have seen any compatability issues between the 2 but like others have said, peace of mind more or less. If you did do a flush, with your miles I wouldn't use a cleaner of any kind, just exchange the fluid. Pan drop/filter is ok too just doesn't get all the old fluid out of the converter etc.
  6. #6 Re: Question about transmission fluid
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by DJNight2k View Post
    Flush is a bad idea...why even bring that word into this thread?
    Pan drop and filter is all you need with DEX III or DEX VI
  7. #7 Re: Question about transmission fluid
    at 200,000 miles a flush is a real bad idea.
    dex 3 is what you want, get the walmart brand.
    when you say the fluid looked clear. you mean light pinkish? better then dark brown or black any day.
  8. #8 Re: Question about transmission fluid
    Nov 2011
    Indiana
    Unless he means rustic orange? Cause that's more towards the side of the fluid color IIRC. But ya, I would say a flush isn't a good idea. Don't want it to clean out your entire system that could be holding your trans together lol. If you can, get Dex 3 for sure. Just do a simple pan drop n filter change and you're good to go.
  9. #9 Re: Question about transmission fluid
    Aug 2013
    mpls, mn
    car may have 198k miles but trans may have been rebuilt at some time. or not. i think a high miles trans should stick with dex3. if trans has been rebuilt and has low miles than go with dex6. i put in used trans and used dex3. was able to add 10qts and i have trouble even seeing fluid on dipstick since its so clean.
  10. #10 Re: Question about transmission fluid
    Jan 2012
    Indianapolis
    I was told the transmission was supposedly rebuilt and "built" at 100K miles. There is no paperwork to back it up and the seller couldn't even tell me what "built" meant. There is however some sort of yellow paint marking on "band applicator pin cover" (I forget the proper name for it). So I assume something has been done with it. But weather it was rebuilt or is from a junkyard who knows.
    The fluid is like a very clear color with a hint of pink if you look at it the right way or wipe it off on a white napkin you can tell it's pink. Its not even as dark as normal tranny fluid IMO. Its almost like its diluted with something clear.
    And I know not to flush the system. The only way I would ever get a car flushed is is if I owned the car since under 30K and had it flushed every 30K miles or if I had a trans rebuilt. Most people ignore maintenance in their tranny on top of the fact that they abuse it and then wonder why its slipping after they decide to flush after 100k miles.
  11. #11 Re: Question about transmission fluid
    GT Level Member 02GPinNY's Avatar
    Aug 2012
    Port Chester, NY
    While on the subject of Fluid, I'm going to have only the pan dropped and filter and a refill of the fluid. My question is: how many quarts of DexIII should I buy for the refill? Also, should I go with the AC Delco Filter or will a Hastings or Purolator Brand be okay. I have 140k on the car and this will be the first time that I'll be dropping the pan. Don't know if the previous owner ever did it or not. Thanks.
    2002 GT Red, Stock, Work In Progress..........
  12. #12 Re: Question about transmission fluid
    Dec 2012
    Where 4T65E's were born
    I originally bought 2 gallons(8 quarts) of Valvoline Dex III which wasn't enough, so I went out and bought another gallon, and ended up using 8.5-9 quarts total. (Then used another quart for a "flush")
    As long as it's compatible, the brand doesn't matter too much, just get a quality filter. I don't know who makes the OE off hand, but Purolator would be a good choice. I used Wix.
    Sold.
  13. #13 Re: Question about transmission fluid
    Aug 2012
    Port Chester, NY
    Thanks Navy! Do you remember if your pan had a rubber gasket or cork? I haven't done this before so I want to be sure beforehand.
  14. #14 Re: Question about transmission fluid
    reuse the gasket if its the stock thick rubber one. i used a duralast filter. so far so good.
  15. #15 Re: Question about transmission fluid
    Aug 2012
    Port Chester, NY
    Thanks Scotty! Sorry I've been away for a while. I've been trying to grab as many miles on the bike as I can while the weather behaves. I haven't put many miles on the GP except for moving it side to side for parking rules. AutoZone had the Duralast and Purolator Filters. They were both about the same price. I'll grab one of them tomorrow. Thanks again!
  1. Transmission Fluid-
    By GTByron in forum Introductions/Noob Questions
    Last Post: 05-20-2013, 11:35 AM
  2. Transmission Fluid - 173K..To change or not to change, that is the question
    By 99XC600 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2012, 10:03 PM
  3. transmission fluid
    By Linebacker in forum General Tech Discussion
    Last Post: 05-17-2012, 08:25 AM
  4. What transmission fluid for 98 gtp?
    By silverPGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-18-2010, 05:22 PM
  5. Transmission fluid
    By ChevMan92 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-23-2010, 07:54 PM
