Thread: GMR Torsen Installed/Pics
Results 1 to 2 of 2
  1. #1 GMR Torsen Installed/Pics
    GTP Level Member
    Pittsburgh
    I will let the pics speak for themselves
    This was a torsen that was used by GM Racing
    Stock HD Diff on the left, the GMR Torsen on the right
    the 2 parking gears. The Left is the stock park gear with bearing, on the right is the Torsen Park gear with a larger bearing. It also appears that the Torsen park gear is machined to accept that bearing.
    The teeth are different although the part number is the same
    Sun gear side
    the sun gear with the modifications for street use. It also appears that the sun gear is heat treated compared to the stock unit
    also a pic of the copper washers on the planets to make the unit for street use.
    I will get to test it out here in a few weeks with my Hoosier Slicks
    2003 SSEi,
  2. #2 Re: GMR Torsen Installed/Pics
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Very nice!
    Interested in more information on the bearing that is on the parking gear. In the Ecotech manual it was something that was never really spoken about other than it was modified. To my knowledge the parking gear was only modified for use with the 4.0 GMR Diff. The core of the Torsen diffs are identical between 3.29 and 4.0 only the planatery gears are what change the ratio. Obviously with the larger planatery gears modifications had to be made for the parking gear when used in the 4.0 ratio.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  1. New bumper installed w/pics! Now I have gap :(
    By firstdue in forum General Grand Prix Discussion
    Last Post: 04-02-2013, 11:13 PM
  2. GPO Grills (Pics Installed)
    By SilverBackGorilla in forum Visual/Body Modifications
    Last Post: 08-14-2012, 05:40 PM
  3. Borla Installed, a few Pics
    By David99GTP in forum Off Topic Discussion
    Last Post: 08-12-2008, 03:49 PM
