Thread: Thinking of changing oil
Results 1 to 6 of 6
  1. #1 Thinking of changing oil
    Aug 2008
    SOUTH TEXAS
    Ive heard people add trans cooler to their oil.
    Which one?
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  2. #2 Re: Thinking of changing oil
    Oklahoma
  3. #3 Re: Thinking of changing oil
    Aug 2008
    SOUTH TEXAS
    I was thinking is was more like an additive.
  4. #4 Re: Thinking of changing oil
    Oklahoma
    Oh, my bad. In that case, dont. If you want the trans to run cooler, there are two great and proven ways to do so. First you can install an auxiliary cooler or you can run synthetic transmission fluid which normally drops temps about 15 - 20* or so. Other than that, I wouldnt run any additives in the transmission fluid or the motor oil.
    The major thing that people overlook when wanting to use additives is additive package compatibility. There could be something in the additive you want to use that may not be completely compatible with the fluid you are using. Typically there is not much of an immediate issue, but with the transmission fluid and as thin as it is to start with I personally wouldnt want to run something that would alter its chemistry at all.
  5. #5 Re: Thinking of changing oil
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by GTP4 View Post
    Which one?
    Are you smoking crack? Oil goes in the 710 cap, and only oil, no transmission fluid, no additives, no salt, or rocks.
  6. #6 Re: Thinking of changing oil
    Jul 2008
    sumter,south carolina
    lmao streetwolf...i think he meant trans fluid not "oil" ...something to ad to the fluid itself to make it run cooler.
    02 GTP with mods 05 GP for DD
  1. Changing engine belt
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-26-2009, 10:47 PM
  2. changing supercharged oil
    By nemesis in forum General Tech Discussion
    Last Post: 08-06-2008, 12:27 PM
  3. Changing the Spark plugs
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2008, 03:24 AM
  4. Changing headlights
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 02-26-2008, 08:56 PM
