Thread: Transmission Swap
Results 1 to 8 of 8
  1. #1 Transmission Swap
    Aug 2013
    Wichita
    I recently realized my transmission on my '97 GTP was basically done after 204,000 miles. I was going to repair it but found another 4t65e-HD with 78,000 miles and bought it. The problem is that it is from an '08 Chevy Impala SS. On my car the starter is mounted to the block and on the new transmission the housing doesn't have the bulge to fit the starter like the old one. Instead it has a place to mount the starter on the housing just on the upper side of the block. I'm wondering if anyone has ran into this and knows if a starter can fit between the block and headers. Also, I am concerned about problems from heat.
  2. #2 Re: Transmission Swap
    It wont work without lots of modifications. You need a trans from a 97-02 and a 98-02 trans you will need to change the cooler line fittings 97s had screw in 98-02 had quick release.
  3. #3 Re: Transmission Swap
    The LS4 transmission is different from your 97 trans. The case, the TCM controls and the PCM.
    It will not work at all.
    You must find a 97-02 HD trans for a 99% direct drop in transmission.
    The only thing that changes in 99 or 00 was the cooler line fittings.
  4. #4 Re: Transmission Swap
    It was 98 when they switched the cooler lines cam. From what I remember 97 was the only year with screw in lines.
  5. #5 Re: Transmission Swap
    Aug 2013
    Wichita
    That's unfortunate. Would I just be able to switch everything out of the new one and rebuild the old then?
  6. #6 Re: Transmission Swap
    Nope.
    Way way too much is different between the years to work.
  7. #7 Re: Transmission Swap
    Aug 2013
    Wichita
    Alright. It was a risk worth the price I paid. Off to figure out something else.
  8. #8 Re: Transmission Swap
    You could use everything up to the valve body and channel plate. Those pieces must be from 97-02 to work in your case with the rest of the parts. Some V8 parts are beefier
  1. Transmission Swap
    By vanherk1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2013, 12:26 PM
  2. Transmission swap.
    By Tuner-Extraordinaire in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-13-2011, 01:54 PM
  3. Transmission Swap
    By cmal37 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-30-2011, 08:42 PM
  4. transmission swap
    By jrock in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-13-2011, 01:04 AM
  5. Transmission swap
    By ddyke2000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-01-2009, 10:19 PM
