Thread: 00 gt top swap trans totalled?
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21 Re: 00 gt top swap trans totalled?
    Antioch, IL
    weld a rod into the center.
    in neutral it will spin mine did, i hated that sound
    2009 Challenger SRT8
    Expert at being gay.
  2. #22 Re: 00 gt top swap trans totalled?
    SE Level Member MissLexx's Avatar
    Apr 2013
    Brookings, SD
    Quote Originally Posted by FordMan77 View Post
    Maybe JB weld some threaded rod to the center of the broken axle shaft, stick a thick washer on it and then a nut at the end of the rod to keep the washer in place and then use a slide hammer to pop it loose. Either that or have someone weld it to it, but not sure if all that heat would be good for the seals around it.
    Technically it only has to hold enough to get the c-clip on the end of the axle to pop free from the trans and out it comes. I'd think some JB would hold enough for that.
    Also, not sure how good of luck you'd have drilling into the anyway as it's probably some super hard steel.
    THis is probably another noob question but how does the c-clip come off of the axle, it will just pull out and grab the new axle when i slide it in?
    05' GTP Comp G "pretty in pink"
    00' GT w/ gtp top swap
  3. #23 Re: 00 gt top swap trans totalled?
    St. Louis
    The C-clip is attached to the end that is still in the trans. When you get your new CV axle there should be a new clip on the trans. end already. No need to remove the old one from the broken piece.
    Yes, it will pop loose from the trans and then when you install the new axle give it a shove inward towards the trans. and it will click into place.
  4. #24 Re: 00 gt top swap trans totalled?
    Apr 2013
    Brookings, SD
    Thanks!
  5. #25 Re: 00 gt top swap trans totalled?
    Ohio
    Ohh.. But according to Facebook, you said it was your dumbass lsx boyfriend that did this...
    #Girlproblems
  6. #26 Re: 00 gt top swap trans totalled?
    Apr 2013
    Brookings, SD
    Quote Originally Posted by MoarkatsINmuhtrailer View Post
    #Girlproblems
    Reread the comments I never once said that. All I said is hes the reason I am into cars.... but thanks for your input :/ im not pointing fingers at who did it im just interested in fixing the car, thanks to everyone and your helpful input. I have an hd axle and diff on the way and will be working on it soon!
  7. #27 Re: 00 gt top swap trans totalled?
    Ohio
    ... Well anyways, just smack the output shaft from the other side and it should pop the diff out as well. Just make sure to unbolt the diff cover.
  8. #28 Re: 00 gt top swap trans totalled?
    Apr 2013
    Brookings, SD
    Thanks, I've ordered an had axle and will have an hd diff on the way. I see the zzp hd upgrade kit includes an hd diff cover too, I suppose i need one of these for the bigger hd axle? Does anyone have one I could buy off of them?
  9. #29 Re: 00 gt top swap trans totalled?
    Ohio
    I did. Sold it recently though.
  10. #30 Re: 00 gt top swap trans totalled?
    The way to fix this.
    Drain trans.
    Remove rest of passenger axle from wheel bearing
    Remove the engine to trans bracket
    Disconnect the VSS (sensor on trans cover right by axle)
    Remove other two bolts holding cover on trans
    Remove cover
    With big screwdriver between diff pin and output shaft, give it a whack to seperate it.
    Now the diff is in your hand. Either put a new one in or pop the old shaft since it's in your hand.
    Reinstall and put in a new axle. While you are at it.. fix the driverside too.
  11. #31 Re: 00 gt top swap trans totalled?
    Apr 2013
    Brookings, SD
    thats great thank you. when my parts get here i will tear into it
  12. #32 Re: 00 gt top swap trans totalled?
    Apr 2013
    Brookings, SD
    We picked up a trans and diff today, someone want to tell me how we can tell if it really is an hd differential?
  1. trans swap
    By STW in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-02-2012, 09:22 PM
  2. Trans swap
    By 443pearl in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-01-2012, 09:56 PM
  3. Trans Swap
    By Terry102 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-25-2011, 08:38 PM
  4. trans swap
    By GOINDEF in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2011, 01:13 PM
  5. Trans/PCM swap
    Last Post: 10-06-2009, 09:13 PM
