Thread: Loose flex plate symptoms?
Results 1 to 3 of 3
  1. #1 Loose flex plate symptoms?
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Anybody ever have a loose bolt on your flexplate? If so what were your symptoms? I have a vibrating noise coming from that area under easy to mid acceleration. I recently rebuilt this motor and reused the old bolts that bolt to the motor. (I posted up before re-using them and people on here told me to re-use them with a little blue lock tight which I did) Pretty sure I used ARP ones to the converter. I haven't crawled under the car and looked in there yet but will tomorrow morning. Just looking for posts from people who have had loose bolts on the flex plate. I don't think its motor related or a mount.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  2. #2 Re: Loose flex plate symptoms?
    Loose bolts there could sound like a rod knock, seen it happen on a jeep at work.
  3. #3 Re: Loose flex plate symptoms?
    Typically it's flex to converter that loosen up. Crawl under...
  1. flex plate
    By Eric Whitter in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-31-2013, 09:52 PM
  2. Flex plate bolts
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2012, 09:21 AM
  3. Symptoms of broken flex plate?
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-21-2011, 08:18 PM
  4. flex plate
    By tihosick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-10-2009, 10:25 AM
