Thread: 4t65e HD OK after GM rebuild?
Results 1 to 7 of 7
  1. #1 4t65e HD OK after GM rebuild?
    Jul 2013
    Missouri
    Hi all, new to forum, name is Garrett! looking to buy a 08 GXP from an individual, he is second owner bought from local GM dealer w/30,xxx, trans started slipping, GM rebuilt it under warranty around 40-50,xxx miles, has 63,000 on it now, wife driven to work and back.... Should i be afraid of this or does the GM rebuild remedy this problem?? thanks for all feedback
  2. #2 Re: 4t65e HD OK after GM rebuild?
    Aug 2011
    'Merica
    These trans are glass in the GXP. It should be fine after you install a tranny cooler. There are a few write ups on hot to do this.
  3. #3 Re: 4t65e HD OK after GM rebuild?
    Jul 2013
    Missouri
    Is there by chance a factory trans cooler? or should i go with a particular aftermarket brand?
  4. #4 Re: 4t65e HD OK after GM rebuild?
    Aug 2011
    'Merica
    hit the search button on the top of the home screen. it is hard to find but you will notice the magnifying glass. You will find a lot of good info there.
  5. #5 Re: 4t65e HD OK after GM rebuild?
    Jul 2013
    Missouri
    done some searching, found lots of great information, thanks! Also called the local GM dealer with the last 8 of the VIN, he told me the history of what was fixed ( including trans cooler lines) the service guy told me its common to the radiator on the 08 and that after a rebuild there should be no worries especially after a mild mannered woman has been driving it! haha
  6. #6 Re: 4t65e HD OK after GM rebuild?
    I live here. DirtDog's Avatar
    Jun 2012
    Id still do an after market tranny cooler. If u pay attention to the DIC you'll see the tranny temp get in the 200's with stock radiator. I recommend an after market unit ASAP with the summer here. Recommend goal to keep the temps at is below 190.
  7. #7 Re: 4t65e HD OK after GM rebuild?
    Jun 2012
    Also a tranny pan drop and install a shift kit will help with prolonging the life of the tranny and when u drop the pan u can see if previous owner was a jerk to the car or not
  1. 4T65E rebuild DVD!!
    By chrisb in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-05-2017, 01:54 PM
  2. 4t65e rebuild...the sequel...
    By MontyJ in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-22-2012, 10:33 AM
  3. 4t65e rebuild...
    Last Post: 08-05-2012, 02:52 AM
  4. Alldata rebuild hours for 4T65E HD
    By Spartan GL in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-11-2011, 09:12 AM
  5. Official 4t65e-HD Rebuild
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-09-2010, 09:14 PM
