Thread: output shaft comes out
Results 1 to 11 of 11
  1. #1 output shaft comes out
    May 2011
    ohio
    i bought a totaled gtp that was hit around the door but snaped the tie rod and broke the axle both in half. but the output shaft just comes right out out is that suppose to happen should i be worried about any transmission parts being messed up?
  2. #2 Re: output shaft comes out
    I live here. DirtDog's Avatar
    Jun 2012
    The output one on drivers side?
    Looks like this
  3. #3 Re: output shaft comes out
    HUDSON
    The clip is broken that holds the spider gear in the diff. to the axle. It would be a good idea to remover the diff. cover and diff. assembly to remove the pieces so they do not end up between the gears and causing more damage.
  4. #4 Re: output shaft comes out
    Jun 2012
    Quote Originally Posted by QUICKSILVER462 View Post
    Bro he didn't say anything about it breaking...just ask if it was supposed to come out. If on drivers side yes its fine and will go back in. Now the clip he is referring to is the tiny one there should be one on both ends of the shaft. Make sure their there. If not do what ^^^^^ said
  5. #5 Re: output shaft comes out
    There is a clip at each end. The one at the diff let go easier than the one on the axle.. no big deal. Pound the axle piece off the shaft and reinsert it. Once it's in place give it a whack to seat it the last 3/4" or so into the diff. Now put the new axle in.
  6. #6 Re: output shaft comes out
    May 2011
    ohio
    thanks guys for the feedback
  7. #7 Re: output shaft comes out
    Zach..one thing I forgot to metnion. Make sure you put the correct end back in the trans first. There is a difference.
  8. #8 Re: output shaft comes out
    Jun 2012
    If u look at my pic up there the end that has a couple inches of shiny smooth section is the end the CV shaft goes on. Other end is the end that goes in the tranny
  9. #9 Re: output shaft comes out
    Actually it's easier if we tell him the end with the longer splines is the axle end.
  10. #10 Re: output shaft comes out
    Jun 2012
    That's why we keep u around....always thinking of the simplest ways
  11. #11 Re: output shaft comes out
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    Yes there is found that out.
    97 Bonneville SE Not so much a 97 anymore
  1. output shaft play?
    By chuckd98gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2014, 07:13 PM
  2. Gun Drilled Output shaft
    By MidnightBlue in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-19-2011, 05:48 PM
  3. Output shaft questions?
    By johnsmith in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-10-2010, 07:58 PM
  4. Q? Output Shaft removal
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-22-2008, 09:07 AM
