Thread: Gemini dual chain or 7/8" single?
Results 1 to 11 of 11
  1. #1 Gemini dual chain or 7/8" single?
    GTX Level Member crbquist's Avatar
    Massachusetts
    The stock trans on my car is slipping pretty bad so I am currently researching a new trans option. My best bet seems to be the TEP route, so I shot Dave an email in regards to what trans setup would be best for me, etc. His response was that their stage 1 performance trans with an upgraded input shaft would be fine for my current mods (see sig). He implied that a new stock dual Gemini chain would be fine for my mod level and that it would actually last longer than the upgraded 7/8" single chain under normal use. He said the 7/8" chain would be ideal if I were making 330+whp and wanting to making frequent passes at the track running sticky tires. Sooo, what should I do? I do not intend to race the car, but I may hit the track someday just to see what it runs. Also, I plan on converting to E85 when it becomes more available hence creating more power. Should I listen to TEP and just run a dual chain or spend the extra coin on the upgraded 7/8"? Would a 7/8" chain last a long while?
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  2. #2 Re: Gemini dual chain or 7/8" single?
    SE Level Member 92bird's Avatar
    Colorado
    Yes. He's a walking 4t65e bible, I'm amazed at how much this guy knows. The new dual chain he uses is a hardened version that GM developed for the 303hp grand prix GXP. It has its limitations, but looking at your mods I'd say you'd be fine with it.
    Has anyone even broken a GXP chain set yet?
    2000 GTP: ZZP Z7 turbo kit,Precision 5858cea Billet turbo,F&R p-logs,L26 upper/lower,HV3 insert,60lb inj,L67 Throttle/MAF,1.95 Yella Terra rockers,PAC 105 springs/titanium retainers,3" exhaust,full suspension,Self-built 4t65e with zzp 300m input shaft, TEP 7/8" 2.93 chain set, blue plate clutches,PI 2800 stall billet cover converter
  3. #3 Re: Gemini dual chain or 7/8" single?
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    go big or go home
  4. #4 Re: Gemini dual chain or 7/8" single?
    7/8" stretches on hard launches, ask if the V8's do as well. Heck, you were there when I noticed the last 7/8" stretch and again reluctor was torn off. It comes down to normal driving. The V8 chains are very good and hold a lot of power, Dave would be the one to know best on if 7/8" are stronger than V8 etc.
    You can destroy either chain setup by driving the way I did. Look at the way Dan and Nick drive.. sure seems the rolling race is a lot easier on the chains. A few track passes shouldn't hurt either chain setup though.
  5. #5 Re: Gemini dual chain or 7/8" single?
    May 2008
    Schuyler, NE
    I would go with Dave's recommendation and run the stock chain.
  6. #6 Re: Gemini dual chain or 7/8" single?
    Massachusetts
    Haha I remember that night. Bonnie hits the 130 mph mark twice then poof.
  7. #7 Re: Gemini dual chain or 7/8" single?
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    I'm on the fence on this one....If it were my decision I'd really have to ask myself how serious you were about tracking the car and running E85. Next big question would be are you going to be using drag radial or slicks...
    I have a very similar setup to yours and on E85 without and IC and without P&P head I put down 330whp/400wtq. When talking with Dave at TEP I had plans of pushing my setup to the 350whp and that's when he led me towards running the 7/8" setup.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  8. #8 Re: Gemini dual chain or 7/8" single?
    That was probably under 2000 miles on a new chain and gearset. Chain stretched enough and was dragging in the case, the feeling/noise was the reluctor after it tore off the gearset. I've seen your driving and I think you'll be ok either way.
  9. #9 Re: Gemini dual chain or 7/8" single?
    Apr 2011
    Columbus, OH
    If you don't in any way shape or form drive like Bill run the dual gemini setup.
  10. #10 Re: Gemini dual chain or 7/8" single?
    Chris... on the E85, it's a great idea, I have not heard anything on expansion in our area. Trying to find it is difficult around here and unless you've found info about it coming in soon. I can't foresee it happening in the next 2 years.
  11. #11 Re: Gemini dual chain or 7/8" single?
    Massachusetts
    If only I still lived in Holyoke.. Racing mart about 15 min away in Northampton carries it.
  1. Dual or Single exhaust...
    By HighOctaneRacing in forum General W body
    Last Post: 03-13-2011, 11:56 AM
  2. single or dual tips?
    By biggt in forum Visual/Body Modifications
    Last Post: 03-09-2011, 07:44 PM
  3. Question on single chain
    By 00gpgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-21-2009, 11:15 AM
  4. single to dual exhaust?
    By Jcal1120 in forum General Tech Discussion
    Last Post: 08-15-2009, 12:51 AM
