Thread: p1811 hard shifting problem burnt trans fluid
Results 1 to 5 of 5
  1. #1 p1811 hard shifting problem burnt trans fluid
    SE Level Member skylar44's Avatar
    Jul 2012
    Toronto
    Bought the car back in December, it's an 05 Grand Prix GT with about 180,000km (~112k miles) on it now. It's been shifting hard occasionally since Januaryish?
    Anyways it usually shifts hard when I'm either stuck in stop and go traffic or it's hot outside. Shifts hard from 1-2, 2-3, not sure about 3-4. Sometimes it slams into first after coming to a complete stop. Transmission fluid is brown, burnt, and has metal shavings.
    I was on my way to my dad's friends transmission shop to change the fluid and it started shifting hard and late and the car wasn't warmed up. He scanned the car and came back with a p1811 max adapt long shift between 1-2, apparently the slip was a couple hundred rpm. He looked at the fluid and said if he services it for a flush/change he'll probably make it worse.
    He quoted me $1800 for a complete transmission rebuild including GM OE parts, updated parts, and a new torque converter. He said the valves and clutches are probably worn, and the torque converter is probably fine but he'd rather be safe and replace it if he's replacing everything else.
    Just wanted your guy's input. Could it just be the EPC Solenoid, or is it worth it to rebuild the transmission?
  2. #2 Re: p1811 hard shifting problem burnt trans fluid
    If its been doing it since like 6 months ago, its prolly cooked the insides.
    If it was me, I'd rebuild it or get a used transmission.
  3. #3 Re: p1811 hard shifting problem burnt trans fluid
    Could get some more life out of it with a pan drop transgo shift kit and a bottle of lucas.
  4. #4 Re: p1811 hard shifting problem burnt trans fluid
    Jul 2012
    Toronto
    I'm pretty limited myself in time/tools. How much would getting a shiftkit installed run me?
  5. #5 Re: p1811 hard shifting problem burnt trans fluid
    Not much more than a pan drop and filter change.
  1. 4T65E Code P1811, hard shifting, along with stalling at idle...
    By 2002GrandPrixGT40th in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-22-2014, 05:30 PM
  2. hard shifting when trans heats up?
    By 2002 grand prix gt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-12-2012, 09:45 PM
  3. trans just started shifting hard
    By hardrocrick in forum General Tech Discussion
    Last Post: 08-25-2011, 03:12 PM
  4. Burnt fluid in a trans with only 3k tops on it???
    By Kejross in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-04-2010, 09:06 PM
  5. Help again with trans shifting a bit hard
    By ajm786 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-22-2009, 08:27 PM
