Thread: 98 grand prix transmission repair questions
Results 1 to 8 of 8
  1. #1 98 grand prix transmission repair questions
    Aug 2012
    RI
    Hey guys my buddies gtp started to buck much like me regal did. He took it to a transmission shop, the tech there said he would have to replace the epc valve solenoid and the valve body. He got a code 1811. he was estimated 1200 dollars.
    In my knowledge with these cars. when this happens you replace the tcc solenoid, the pressure control solenoid, and the epc. You don't have to even touch the valve body am I correct.
    I contacted my local transmission shop about this they told me that replacing the valves alone would not likely fix the problem and its only like a 30% chance that it will work. Does any of this sound right to you guys?
  2. #2 Re: 98 grand prix transmission repair questions
    for another 500 he could get a full re build.
    mine did the bucking deal in 3 rd gear for a while, then i lost 3 rd gear. a used tranny was my fix.
  3. #3 Re: 98 grand prix transmission repair questions
    Just replace it It's easier in the long run
  4. #4 Re: 98 grand prix transmission repair questions
    Aug 2012
    RI
    well the car only has 130k on it and shifts like a champ, it was owned by his dad before he got it. the transmission still has loads of life in it. I guess what I am asking is if he was to just get at the side pan and repair the likely suspects would that fix his problem without replacing the valve body.
  5. #5 Re: 98 grand prix transmission repair questions
    theres a how to for changing those sensors, the side cover has to come off the tranny. it can be done in the car, but its not one of them 100% deals.
  6. #6 Re: 98 grand prix transmission repair questions
    GT Level Member 88formula's Avatar
    Oct 2012
    West Branch, MI
    Tell your friend to just buy my transmission. I drove the car it came out of so I know it is good. 40k original miles on it, out of a 98 GTP, has new TransGo shift kit, filter, pan gasket, and high temp Aluminum paint job. Was going to use it in my 3800 Fiero I was building, but I sold the car, and motor. $500+shipping
    1997 Regal GS, L26 N/A block, 'Reptile' Ported Gen 3 Blower w/3.5 pulley, VS cam, K&N Open Cone, Speed Daddy Headers, 3" cat and res, Dual 2.5" Dynomax mufflers w/C6 Corvette tips. PLX Wideband, Custom Dyno Tuned By Jeff @ Engineered Performance. Lucerne 17's, F-Body Brakes.
  7. #7 Re: 98 grand prix transmission repair questions
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    So the trans shop quoted your friend $1200.
    For $1375 shipped to your door with new torque converter....and not to mention a warranty.
    This is a what a "full rebuild" should really look like. Typically a trans shop only repairs the problem without thoroughly going through the entire trans inspecting and replacing wear items as needed.
    New-Back to Basix
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  8. #8 Re: 98 grand prix transmission repair questions
    EPC and pressure solenoid are the same. Most bandaid it with a shift kit.
  1. 94 Grand Prix SE coupe rust repair??
    By Jmann96 in forum Brakes/Suspension/Chassis
    Last Post: 04-22-2013, 08:09 PM
  2. 2004 Pontiac Grand Prix window switch repair
    By agatorhawk2 in forum General Grand Prix Discussion
    Last Post: 10-26-2012, 03:35 PM
  3. 02 Grand Prix Transmission Questions...
    By Zetah in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-26-2011, 09:56 AM
  4. 1998 Grand Prix GTP Transmission questions.
    By RavagerX in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-16-2010, 06:00 PM
  5. $500 97 Grand Prix GT Repair Progress
    By InfidelRebel in forum General Tech Discussion
    Last Post: 10-28-2009, 09:41 PM
