Thread: 2004 gtp comp g transmission overheating
Results 1 to 18 of 18
  1. #1 2004 gtp comp g transmission overheating
    Mar 2013
    Burton,MI
    Today I was driving on the highway and city and noticed my trans was running 200. And I'm guessing that's hot. What can I do to lower the temp other then a trans cooler. Please help thanks
  2. #2 Re: 2004 gtp comp g transmission overheating
    200 isnt hot, thats a normal temp for it to be around.
    Other than changing the fluid and filter and running a trans cooler, you can't really do anything to reduce the temps.
  3. #3 Re: 2004 gtp comp g transmission overheating
    Just add a trans cooler and call it good
  4. #4 Re: 2004 gtp comp g transmission overheating
    200 is considered normal operating temp. Smile and have a beer
  5. #5 Re: 2004 gtp comp g transmission overheating
    May 2013
    Upstate NY
    How hot is to hot tho? I know with my cummins truck 210-250 is frowned upon. My 04 comp G runs 200-210 and Ive seen it hit 230 on a windy uphill section using the tap shift. Are these gauges really that accurate?
  6. #6 Re: 2004 gtp comp g transmission overheating
    They are accurate. I don't like mine over 180 but that's just me
  7. #7 Re: 2004 gtp comp g transmission overheating
    May 2008
    Schuyler, NE
    If you see it get above 230*, that's probably getting too hot.
  8. #8 Re: 2004 gtp comp g transmission overheating
    Pennsylvania
    Old fluid does not dissipate heat well. Git sum phresh.
  9. #9 Re: 2004 gtp comp g transmission overheating
    Jul 2013
    San Bernardino,Ca
    To flush or not to flush ?
  10. #10 Re: 2004 gtp comp g transmission overheating
    Quote Originally Posted by kingspadeshan View Post
    No flush.
    Pan drop, filter change, new fluid.
  11. #11 Re: 2004 gtp comp g transmission overheating
    Jul 2013
    San Bernardino,Ca
    How often? I just got one with 82,500 on it with no maintenance records.
  12. #12 Re: 2004 gtp comp g transmission overheating
    Flush if you want to and don't be surprised if your trans needs rebuilding afterwards. Stock with a pan drop.
    04 Comp G.
  13. #13 Re: 2004 gtp comp g transmission overheating
    If it was my car, every 50-75k miles.
    Likely your car has never had it done, so do it now for peace of mind.
  14. #14 Re: 2004 gtp comp g transmission overheating
    Jul 2013
    San Bernardino,Ca
    Thanks
  15. #15 Re: 2004 gtp comp g transmission overheating
    Jul 2013
    San Bernardino,Ca
    Picking car up right now. They said they flushed it and I told the not to and they didn't replace the trans filter. Idiots!!
  16. #16 Re: 2004 gtp comp g transmission overheating
    Jul 2013
    San Bernardino,Ca
    Well since they flushed it anyways how long do u think before I have trans issues? Idiots didn't even change the filter....
  17. #17 Re: 2004 gtp comp g transmission overheating
    Pennsylvania
    They didn't replace the filter?
    Slash their tires.
    Flush probably won't hurt anything. The filter is super important, though. Get that fixed.
    And since you're not taking the car to that mechanic anymore (Right?), unhook your battery for a half hour to let the trans settings reset for the new fluid.
  18. #18 Re: 2004 gtp comp g transmission overheating
    Jul 2013
    San Bernardino,Ca
    Well these bastards dicked around and 2 hrs later tell me they got a defective gasket and the car won't be ready until tomorrow. I told then the least they can do is replace that filter. Sad part is that I will not know if they actually change it. I'm going to call in the morning and request that I see it.
  1. 2004 Comp G transmission Filter.
    By Iceman83 in forum General Grand Prix Discussion
    Last Post: 02-24-2013, 07:48 PM
  2. 2004 grand prix gt overheating help
    By woods62988 in forum General Grand Prix Discussion
    Last Post: 12-21-2012, 01:27 AM
  3. 2004 Grand Prix Comp G transmission issues...
    By balt1024 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-30-2012, 07:49 AM
  4. 2004 GP-GT2... blown intake manifold, overheating, etc
    By gunbunny in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-17-2012, 09:07 AM
  5. 2004 GTP COMP G warm weather transmission problem?
    By Kodiak19 in forum General Tech Discussion
    Last Post: 07-26-2011, 02:11 PM
