Thread: what o-ring size and material for the top trans line fitting?
Results 1 to 3 of 3
  1. #1 what o-ring size and material for the top trans line fitting?
    SE Level Member alacran's Avatar
    Apr 2008
    Chicago, IL
    Situation - I had to replace the condenser so I pulled the fans, radiator, and condenser. Replaced it, and then put everything back. I lost the o-ring for the top oil cooler line going into the radiator, so I bought an o-ring kit from Autozone, replaced the o-ring and attached everything.
    The fitting(at the threads) is leaking. I've unscrewed it and double-checked everything at least three times. I don't know what to do. Bigger o-ring? Plumbers tape? .
    I FINALLY have ice cold a/c, but I'm leaking trans fluid when I drive. Pretty much defeats the fun.
    TIA
    Nick
  2. #2 Re: what o-ring size and material for the top trans line fitting?
    So the fitting going to the rad is leaking or where the trans line quick connects inside the fitting?
  3. #3 Re: what o-ring size and material for the top trans line fitting?
    Apr 2008
    Chicago, IL
    ClubGP Message Forum troubleshooting
    Here is the detail...
  1. Spyder Halo Ring Size?
    By Points70 in forum Visual/Body Modifications
    Last Post: 06-26-2012, 03:06 AM
  2. Halo ring size?
    By Larmondmj in forum Audio, Security & Visual Electronics
    Last Post: 12-06-2011, 12:20 AM
  3. T-Fitting for my vacuum line & boost gauge.
    By DnaProdigy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2009, 03:18 PM
  4. T-Fitting for my vacuum line & boost gauge.
    By DnaProdigy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2009, 02:36 PM
  5. brake line fitting ?
    By quiksilvergt in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 06:42 PM
