Thread: what is my differential ratio, and first gear ratio?
Results 1 to 7 of 7
  1. #1 what is my differential ratio, and first gear ratio?
    Aug 2008
    Long Island, New York
    my car is a 2000 gtp and i wanted to know what the stock differential ratio is in it... also what is the first gear ratio?
  2. #2 Re: what is my differential ratio, and first gear ratio?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    -The Differential or Final Drive ratio of your 00 GTP is 3.29:1 .
    -The Overall ratio of that trans is 2.93:1 because of the sprockets for the drive chain, which in your trans is a 37 tooth Drive sprocket and 33 tooth Driven sprocket.
    -Here are the gear ratios for the 4T65E
    1st 2.92:1
    2nd 1.56:1
    3rd 1:1
    4th (OD) .070:1
    Reverse 2.38:1
  3. #3 Re: what is my differential ratio, and first gear ratio?
    Barksdale AFB, LA
    Be careful how you word your question.
    Your differential ratio is 3.29. But, due to different numbers of teeth on the drive/driven sprockets of the HD transmission, your actual final drive ratio becomes 2.93.
    First gear for all 4T65Es is 2.92.
    Edit: Damn, beaten by Trannyman.
    2009 Subaru Impreza WRX STI
  4. #4 Re: what is my differential ratio, and first gear ratio?
    Aug 2008
    ok, i see... now i plan to eventually get the intense LSD in my car, if i get the one with 3.29 gearing in my car then that is the stock ratio?
  5. #5 Re: what is my differential ratio, and first gear ratio?
    Fort Wayne, IN
    That is correct- HD/Supercharged differentials that came in the GTPs were a 3.29 ratio and that is what the LSDs are also.
  6. #6 Re: what is my differential ratio, and first gear ratio?
    Aug 2008
    oh... ok, i think hey have options on the lsd's for higher ratios... you would need to tune the car to make this work with the speedometer and everything right?
  7. #7 Re: what is my differential ratio, and first gear ratio?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by 2000GTP View Post
    I seriously doubt they have options for different ratios, as the previous posters said, ALL HD diff are 3.29:1. The gearing changes come through changing the sprockets on the chain on the input side of the trans. Now, they may offer to have different VSS reluctor wheels installed on the diff for different gear ratios, but those don't change the gear ratio itself, they are just for tricking the computer after you have changed the sprockets.
    2001 Buick Regal LS - Almost Stock
  1. 4T60/E/4T65E Sprocket Ratio Swap !!! [*]
    By Trannyman95 in forum How To Write-Ups/Tech Tips
    Last Post: 04-08-2015, 10:14 AM
  2. HD-Differential gear difference!! Please help me!!!
    By copgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-27-2008, 04:46 PM
