Thread: Normal or shift flare
Results 1 to 4 of 4
  1. #1 Normal or shift flare
    May 2013
    US
    Hey everyone,
    When driving my 07 GXP, right around 50-55 when I am driving under regular acceleration, I notice my RPM's jump right before shifting:
    Shift flare at 50MPH? - YouTube
    Starts around 13 seconds or so.
    Is this normal or should I get this looked into?
  2. #2 Re: Normal or shift flare
    Might just be the torque converter locking.
  3. #3 Re: Normal or shift flare
    Feb 2008
    If your converter is locked during 3rd gear, it unlocks before the trans shifts into 4th. The two actions are supposed to occur almost simultaneously, but the delay tends to grow on higher-mileage transmissions. Mine does the same unless I disable lockup during 3rd gear, but then MPG's suffer a bit since most of the streets I drive are 35-45. I wouldn't worry about it too much, but a fluid/filter change probably wouldn't be a bad idea.
  4. #4 Re: Normal or shift flare
    May 2013
    US
    Thanks for the replies, feeling a bit better about it now. I called and made an appointment Monday for a pan drop, fluid/filter change. Will get it in on Saturday.
  1. Replies: 1
    Last Post: 12-08-2012, 07:39 PM
  2. Fender Flare
    By walkure in forum Visual/Body Modifications
    Last Post: 06-18-2012, 03:26 PM
  3. Trans Slips Between shift when in normal
    By shawnschuldt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-16-2011, 09:25 AM
  4. Is this normal?
    By PurpleGuy in forum Audio, Security & Visual Electronics
    Last Post: 01-13-2011, 08:12 PM
  5. Replies: 1
    Last Post: 09-23-2009, 06:05 PM
