Thread: Sonnax Billet 3rd Housing/Piston
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Sonnax Billet 3rd Housing/Piston
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    Anyone able to buy this yet? I'm totally in for one.
    97 Bonneville SE Not so much a 97 anymore
  2. #22 Re: Sonnax Billet 3rd Housing/Piston
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    Still waiting for sonnax. I cal every day so as soon as I know you guys will know.
    I would just call Dave @ TEP about the valve body, his stage 2 valve body comes with those upgraded valves. I just got mine back from him a month or so ago. Send him your VB and spacer plate and he will send it back ready to go. All new solenoids too etc. Def worth it!
  3. #23 Re: Sonnax Billet 3rd Housing/Piston
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Called in today to get any additional updates.
    Cost is $130 and is drop shipped to your door.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  4. #24 Re: Sonnax Billet 3rd Housing/Piston
    some good info on gmpp trans chains - Page 2 - TCG
    dave at 3ep put up a good point that increasing that surface area is gonna make its clamping at any given line pressure to be way above the other gear clutches so its gonna slam..... since you cant adjust line pressure relative to current gear.
    i could see using a stiffer spring in the 2-3 accumulator to try and ease pressure rise with a larger volume but ultimately you arent gonna be extremly happy at part throttle upshifts unless you make your other gears relatively soft via main line pressure
  5. #25 Re: Sonnax Billet 3rd Housing/Piston
    Basically, Matt says it's a good idea to 100% line pressure: everything
  6. #26 Re: Sonnax Billet 3rd Housing/Piston
    Well....
    Really all I'm saying is someone said Dave said shifts into and out of third will be much more abrupt regardless of any attempt to modify line pressure.
    But I'm not sure I follow entirely. I see you can set the line pressure for shifts separately in a 3800 P03/P04 PCM. I'm not sure how that translates into the transmission though.
  1. Could this be a hole in #1 piston?
    By guys00gtp in forum Off Topic Discussion
    Last Post: 06-24-2010, 03:27 PM
  2. ZZP Billet TB
    By TNTSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2008, 04:16 PM
