Thread: 98-02 4t65e into an 04 GT
Results 1 to 2 of 2
  1. #1 98-02 4t65e into an 04 GT
    SE Level Member Wakeboy1337's Avatar
    Dec 2010
    Fort Pierce, Florida, United States
    Alrighty guys, as time closes for me to install my built 98 tranny from my parted out 01 GTP into my new 04 GT,(NA for now, and non tap shift model) I need to know what else I need to do.
    Here is what I've done so far,
    added the wires to the 04 so I could run the extrenal PnP switch via billboost's tutoural. (turned the inition on and hooked up the switch, works like a champ)
    Installed the threaded lines onto the 04.
    I've heard something about needing to swap 2 pins on the main connector but I cant find anything with a search and I was hoping someone could shed some light onto which ones.
  2. #2 Re: 98-02 4t65e into an 04 GT
    Boy..this would be so much easier if you had kept it with the first time you asked about it and my response was there.
  1. Tranny Swap 4T65E-HD to 4t65E
    By windowrattler in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2012, 03:47 PM
  2. 4t65e to 4t65e-hd swap
    By kc199 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-22-2011, 04:11 PM
  3. 4t65E replacing 4t65e-hd question
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2010, 10:33 PM
  4. 4t65e-hd in a l36
    By nascartech in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-15-2010, 05:39 PM
  5. "97" 4t65e-hd succesfully installed replacing the "00" 4t65e-hd
    By mikedinthecity in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-06-2009, 01:42 PM
