Thread: Best fluid for high power cars
Results 1 to 11 of 11
  1. #1 Best fluid for high power cars
    Jan 2012
    N/A
    Running a turbo setup over 400whp, Best fluid ? or doesnt it matter.
  2. #2 Re: Best fluid for high power cars
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    Assuming your trans is built, whatever the builder recommends for it.
  3. #3 Re: Best fluid for high power cars
    Jan 2012
    N/A
    Quote Originally Posted by LS1GTP View Post
    Makes sense lol. Andrew Schnicke is the one who did mine. replacing a 4th clutch, and was just curious.
  4. #4 Re: Best fluid for high power cars
    Sep 2012
    Clarkston, MI
    Cool man hopefully we'll run into each other on woodward I'd love to see your car. I go out on Friday nights if I'm able to.
  5. #5 Re: Best fluid for high power cars
    Jan 2012
    N/A
    Im from saginaw, so during summer i want to get down there on fridays. Shoot me PM with your #
  6. #6 Re: Best fluid for high power cars
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Conner?
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  7. #7 Re: Best fluid for high power cars
    Omaha, NE
    400HP is high power?
    BRB Watching 1600hp UGR lambos at tx2k13.
    Anyway... M1 synthetic will be fine.
  8. #8 Re: Best fluid for high power cars
    Triple edge sells a 5 quart fluid that helps keep things better lubed, like the differential.
  9. #9 Re: Best fluid for high power cars
    Jan 2012
    N/A
    High power on our glass trannys
  10. #10 Re: Best fluid for high power cars
    Feb 2009
    flintnasty MI
    Our transmissions do ok. If you break them at 400 you are doing something wrong.
  11. #11 Re: Best fluid for high power cars
    SE Level Member kawasaki22106's Avatar
    Ford City, Pennsylvania, United States
    dave at TEP has a special mix he uses as stated above, thats what i am going to use in my new trans that i am building as we speak.
    665whp 584ft lb torque
    93 pump fuel+meth on 26psi
  1. power steering fluid
    By tstaller2005 in forum General Tech Discussion
    Last Post: 05-03-2011, 10:34 AM
  2. Power Steering Fluid
    By Vlad0691 in forum General Tech Discussion
    Last Post: 11-12-2010, 08:48 PM
  3. Power Steering Fluid
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-22-2010, 01:26 AM
  4. What power steering fluid is best?
    By dl1027 in forum General Tech Discussion
    Last Post: 05-09-2010, 07:55 PM
  5. Power Steering fluid leak
    By jokyfo in forum General Tech Discussion
    Last Post: 09-28-2008, 11:24 PM
