Thread: How long does it take to drop a tranny?
Results 1 to 20 of 21
  1. #1 How long does it take to drop a tranny?
    Aug 2008
    Illinois
    Just like the title says, how long does it take to drop the transmission, and the steps involved if you happen to be bored, or in a very helpful mood.
    ~Darrel
  2. #2 Re: How long does it take to drop a tranny?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    I dont have a lift and generally can have them out of the car in about 1.5 hours including draining the fluid. I think somewhere on here there is a writeup about removal proceedures but cant remember so if you cant find it maybe someone will chime in.
  3. #3 Re: How long does it take to drop a tranny?
    Bastard Reptile's Avatar
    Kansas City, MO
    IIRC it takes me about two hours to pull the engine...so 2 hours LOL
  4. #4 Re: How long does it take to drop a tranny?
    Jan 1970
    Maquoketa, Iowa
    As long as you know what needs to be done, it should take around 2-3 hours.
    We pulled one in about 2 hours, had to do a few things extra since it was a bit rusty and some bolts siezed up.
  5. #5 Re: How long does it take to drop a tranny?
    GXP Level Member ryangtp89's Avatar
    Maine
    I would alo like to know what he's asking cause im going toe dropping my tranny. I looked all around here but i couldn't find anything anywhere.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  6. #6 Re: How long does it take to drop a tranny?
    Wichita, KS
    Takes me about 2 hours on average. 3 if I have help. LOL
    ~F~
  7. #7 Re: How long does it take to drop a tranny?
    chi-town
    i'd agree with about two hours , thats how long it took me to pull mine for the first time , but i got lucky and whoever did the engine befor i bought it they left out the rear bottom bolt , what a pain in the azz that one is. hope you got a long extension.
  8. #8 Re: How long does it take to drop a tranny?
    Maine
    Hmmm by the sounds of it, it doesn't seem too long. Soo take one out and put one in shouldnt take no longer than 8 hours.
  9. #9 Re: How long does it take to drop a tranny?
    chi-town
    took me longer to take it out than put it in. about 1.5 hours in. but them again i cleaned the snot out of everything while waiting to get the trans back. gotta love air tools.
  10. #10 Re: How long does it take to drop a tranny?
    Maine
    ^^Haha yes
  11. #11 Re: How long does it take to drop a tranny?
    Aug 2008
    Hamilton, OH
    Did anyone find a procedure? I got my car back from the shop with tranny in the trunk (long story). I'm going to get a junkyard tranny and install. The Haynes manual I have shows supporting the engine with bars etc on top, and using a tranny jack to raise it into position. It also talks about removing the axles.
    My past experience with Haynes says they have a boilerplate procedure, and not everything they say to do actually needs to be done. So if someone has a good procedure, I'd appreciate it.
  12. #12 Re: How long does it take to drop a tranny?
    Maine
    I haven't really found anything good, i have looked everywhere, I need to know exactly how to remove and install the tranny back.
  13. #13 Re: How long does it take to drop a tranny?
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    I can do it in about 10 minutes.
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  14. #14 Re: How long does it take to drop a tranny?
    Jan 1970
    Maquoketa, Iowa
    Here's the brace Cory made when we did his:
    Then just put the tranny back up in there, wiggle things around to get it in place, If you look closely, you can see the axle hanging there behind the bottom of the tranny in this pic:
  15. #15 Re: How long does it take to drop a tranny?
    chi-town
    Quote Originally Posted by FoSHO99 View Post
    the engine hold bracket i used was totally diffrent , it had blue straps
    the only thing i did diffrent than these pics was i popped the lower ball joints loose and unbolted the upper strut mounts and took the complete strut and spindle assembly out of the way, hung the calipers woth zip ties to the upper strut mount bolt holes and dropped the lower control arms with the craddle. with the struts out of the way it was a cake walk. i like to give myself alot of room to work.
  16. #16 Re: How long does it take to drop a tranny?
    GT Level Member japslpr's Avatar
    VA Beach
    I'll be dropping mine out from the bottom. Maybe can do a write up afterwards. Have to fix a TC and some gaskets. Maybe the Sonnax kit as well.
    My question is this, If you don't use a lift and you drop the cradle (I have the engine support tool), what do you use to lower the tranny out of the car and get it back in? 2 jacks and plywood?
    Jae Harris: 1999 GTP, PARTED OUT
    1997 GTP: K&N 9", Stage 3 Gen 3, ZZP Hub w/ 3.25, S/S Headers, T&D Split Ratio RR (I-1.6, E-1.7), DHP 1.0, BEAR Big Brake Kit, 17x9 Cobra R's, GMPP Strut Towers F/R, Stage 1 Custom Cam
  17. #17 Re: How long does it take to drop a tranny?
    chi-town
    i just used a floor jack under the pan with a small pice of plywood between the jack and the pan.
  18. #18 Re: How long does it take to drop a tranny?
    VA Beach
  19. #19 Re: How long does it take to drop a tranny?
    Odessa, MO
    Not very long, just open the door and tell him/her to get out.
    Seriously, I'm with everyone else on this. About two hours should get it done.
  20. #20 Re: How long does it take to drop a tranny?
    Aug 2008
    Hamilton, OH
    I've got my engine properly supported, and I've disconnected the steering from the hubs. This may sound like a stupid question, but neither my Haynes manual or the instructions I've read on another thread mention disconnecting the strut from the hubs. Without the struts disconnected, wont' they try to hold the cradle in place? Am I missing something here, or is Haynes? thanks.
  1. how long should a 99 gt last?
    By Zainoman in forum Off Topic Discussion
    Last Post: 06-16-2009, 10:54 PM
  2. Changing Flexplate - don't have to drop the tranny ?
    By Meemperor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2008, 12:56 PM
  3. Doing a pan drop tomorrow any tips?
    By alacran in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-08-2008, 05:48 PM
  4. power drop
    By Toasty in forum General Tech Discussion
    Last Post: 03-18-2008, 07:36 PM
  5. Kinda Long..But I need help
    By TJs97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2008, 05:17 PM
