Thread: Is it normal to have bubbles on the transmission dipstick?
Results 1 to 6 of 6
  1. #1 Is it normal to have bubbles on the transmission dipstick?
    Oct 2012
    USA
    When I checked the transmission fluid level today, I noticed that there were several small bubbles (probably 5-6 on one side) on the dipstick. The transmission fluid level is right at the full mark or maybe a tiny lower than the full mark (It is pretty hard to see accurately where the fluid line is......). Are the bubbles something I should concern? I have seen online that overfilling transmission fluid can cause bubbles and it is bad for transmission since air does not provide lubrication. But I am not sure whether just several bubbles are normal or something wrong.
  2. #2 Re: Is it normal to have bubbles on the transmission dipstick?
    Small amount of bubbles is normal because the fluid inside the trans is always moving around, if it was all foamy then I'd see an issue.
  3. #3 Re: Is it normal to have bubbles on the transmission dipstick?
    Oct 2012
    USA
    Thank you! I usually see 4-5 bubbles on one side. I think this should be considered as "small amount of bubbles". But I am not sure and I have no idea how foamy looks like. Will a foamy dipstick look like bubble all over the place?
  4. #4 Re: Is it normal to have bubbles on the transmission dipstick?
    Foamy like when you fill a sink with water and dawn dish soap.
  5. #5 Re: Is it normal to have bubbles on the transmission dipstick?
    Oct 2012
    USA
    Quote Originally Posted by slick2500 View Post
    Thank you! It is definitely not that foamy. It looks like the picture I found on web. I usually have a little less bubbles than what the picture shows. Do you think this is acceptable?
  6. #6 Re: Is it normal to have bubbles on the transmission dipstick?
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Acceptable
  1. Normal transmission temp for GXP?
    By Snik225 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-29-2012, 02:20 PM
  2. Small bubbles in trans fluid
    By Gasnmyveins in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-28-2011, 11:27 PM
  3. Rust Bubbles
    By ljmonnin12 in forum Visual/Body Modifications
    Last Post: 03-08-2011, 01:47 AM
  4. Bubbles in coolant/ radiator
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2009, 12:27 PM
