Thread: No shift under WOT
Results 1 to 9 of 9
  1. #1 No shift under WOT
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Great... used starting hp tuners to start messing around with tuning and since I zeroed out torque management it won't shift until 5900rpm where I set my throttle plate to close. Fuel cuts at 6000.
  2. #2 Re: No shift under WOT
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    After taking out torque management have you messed with your shift points? rpm limiter?
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  3. #3 Re: No shift under WOT
    Sep 2012
    North Carolina
    Yeah rev limit to 5900 Closes the throttle plate and fuel cut to 6000.
  4. #4 Re: No shift under WOT
    Apr 2011
    Columbus, OH
    You need a few hundred RPM's separating them.....having the limiter set only 100 rpms past the shift point isn't going to allow enough time for the shift to happen. Typically there is a 300 rpm gap between the 2.....I'd have to look at my tune but I'm sure it's 300-500 rpm difference between shift point and fuel cutoff.
  5. #5 Re: No shift under WOT
    Sep 2012
    North Carolina
    That's my problem. Those aren't my shift points. Car runs passed the speed and rpm that I set and just runs all the way up to throttle plate closing before shifting.
  6. #6 Re: No shift under WOT
    Sep 2012
    North Carolina
    Unless those are what I actually need to shift, but I thought it went off of vehicle speed and rpm.
  7. #7 Re: No shift under WOT
    Apr 2011
    Columbus, OH
    Which tuner are you using? HP tuners or DHP? There are two different tables...there are shift points based on speed and there in one based on RPM. I'm more familiar with HP Tuners.....someone else will have to chime in with DHP experience.
    Edit: I see you are using HP tuners in your first post. So to go back a bit what have you changed and what are you trying to have as the end result?
  8. #8 Re: No shift under WOT
    Switch everything you did back and I wouldnt do that again.
    The trans needs some TM, its not really the best idea to remove it all. Prolly wouldnt want to get rid of more than 15-20% of it.
    Raising the shift points is pointless aswell, the car makes pretty much no power past 5500-5600 rpms, if anything raise it to 5400 and the car will rev to 5600-5700 before it shifts.
  9. #9 Re: No shift under WOT
    Sep 2012
    North Carolina
    Yeah I don't plan on doing that again and just to be clear once more I didn't change the shift points but I did change the rev limiter based on the electronic throttle and I changed fuel cut. I'm just going to find my first couple files and set all the transfer settings back to stock, but I want to keep line pressures a little higher. I only did it all in the first place because of the starting hp tuners topic. Tuning actually worked out well other than the trans settings.
  1. Replies: 1
    Last Post: 12-08-2012, 07:39 PM
  2. 1-2 Shift @ WOT
    By MstangsBware in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-15-2011, 03:17 PM
  3. shift
    By mik01gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2011, 06:18 AM
  4. '97 se no shift
    By tomnan in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 02-05-2011, 12:52 PM
  5. won't shift out of first very well
    By melwil in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-05-2009, 01:07 AM
