Thread: Trans temps 07 GT
Results 1 to 6 of 6
  1. #1 Trans temps 07 GT
    Jun 2011
    ontario
    Just on the road.... It's hot out. My trans temp is steady at 101*C.....Is this normal?
  2. #2 Re: Trans temps 07 GT
    Around that is pretty normal for 04-08 cars, the 97-03 seem to run a tad cooler.
    If you wanted too, you can install a trans cooler to drop the temps a good amount.
  3. #3 Re: Trans temps 07 GT
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    This thread reminds me of something Ive been meaning to ask:
    How hot is too hot for our transmissions? Last summer on the hottest day (95-100) I was on the road, stuck in Boston traffic. My trans temp peaked at 228F. Ive read blogs and forums all over the web that say 170 is too hot.
    And on average, on a strictly freeway trip I see about 180. In the city on a mild day I'll see 200 tops.
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  4. #4 Re: Trans temps 07 GT
    I use this chart.
    So figure around 200ยบ ish the fluid will last 50,000 miles, and if it was my car I would do a little sooner than that.
  5. #5 Re: Trans temps 07 GT
    Jun 2011
    ontario
    Thanks guys. I actually hit 109 shortly after but it was like almost 40*C out with humidity. Converting it was around 228 F that the trans fluid was at for a bit. Anyways I now have 160kms (100 miles) on the car so guess to be safe I should do a fluid change.
  6. #6 Re: Trans temps 07 GT
    One thing to keep in mind.. Our stock thermostat is 195F, the trans cooler is built in. This means the engineers figured that 195F degree fluid was going to cool the trans fluid. When stating that 100C doesn't seem quite so bad does it.. that's only a few degrees (C) difference.
  1. Trans Temps Vary Widely
    By Chadgervais in forum General Grand Prix Discussion
    Last Post: 02-20-2013, 03:43 PM
  2. what are your temps?
    By rell2005 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-24-2012, 06:26 AM
  3. bad gas mileage and trans temps high
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2011, 04:16 AM
  4. crazy high trans temps or no temps!? pics!
    By blknbstd in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-20-2011, 06:07 AM
  5. in take temps
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2009, 05:50 AM
