Thread: transmission clunk
Results 1 to 11 of 11
  1. #1 transmission clunk
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    whenever ever I got from park to drive it clunk or park to reverse clunk or reverse to drive clunk or drive to reverse clunk...lol
    its not a hard clunk its just noticeable and never used to do this, transmission works fine in every other aspect
    im guessing transmission mounts? car has 136 000 kilometres now
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  2. #2 Re: transmission clunk
    lower mounts i bet. pop the hood, then shift it in and out of gear while watching the engine, it should only move maybe 2 inches each way. if more the lowers are bad.
    flipping the dog bones also makes it tighter.
  3. #3 Re: transmission clunk
    St Thomas Ontario
    ok im guessing its them then, my cousin rocked the engine back and forth a month ago and said my mounts were toast. but wasnt clunking then. guessing its getting bad
    I flipped the bones years ago... looks like i should go mount shopping.
  4. #4 Re: transmission clunk
    if they are bad enough the pass side of the engine will shift in the bay. mine made no clunk but boy was the engine sliding back and fourth.
    looked like this when it came out lol
  5. #5 Re: transmission clunk
    St Thomas Ontario
    ya i can gran the UIM and rock the engine back and forth pretty easily.
  6. #6 Re: transmission clunk
    you got that n/a strut bracket still? maybe its broken?
  7. #7 Re: transmission clunk
    St Thomas Ontario
    strut bracket?
    I know somethings but consider myself a newb still lol.
  8. #8 Re: transmission clunk
    check the pass side dog bone mount to the engine, those n/a brackets snap all the time.
  9. #9 Re: transmission clunk
    St Thomas Ontario
    ok will do.
  10. #10 Re: transmission clunk
    St Thomas Ontario
    not broken both brackets are good
  11. #11 Re: transmission clunk
    off to buy lower mounts then.
    should you come across a l67 coil bracket, buy it and put it in your car. they never break.
  1. Clunk...Clunk...Is driving me nuts!!!
    By Burgundyman in forum Brakes/Suspension/Chassis
    Last Post: 04-13-2014, 01:26 PM
  2. 07 Door Clunk
    By ltruax in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2013, 07:49 PM
  3. clunk going into reverse????
    By vader99 in forum General Tech Discussion
    Last Post: 01-20-2010, 07:44 PM
  4. Crack pop clunk
    By Green97GTP in forum Brakes/Suspension/Chassis
    Last Post: 11-06-2009, 06:47 AM
  5. Pop/Clunk Sound
    By JJ91284 in forum Brakes/Suspension/Chassis
    Last Post: 09-30-2008, 02:59 PM
