Thread: Car Pulling to the Right (torque steer, transmission)
Results 1 to 8 of 8
  1. #1 Car Pulling to the Right (torque steer, transmission)
    Feb 2013
    Omaha
    Hey i have a 2007 GP GT and it pulls hard to the right. the allignment is PERFECT. same with the tires and everything else up from my mechanic looked at..
    So he says its a problem with front wheel drive with TORQUE STEERING that makes the tranny pull harder on one side then the other, especially under pressure when i stomp on the gas. Does this sound right?/ no fix?! im kind of mad because the dealer said they would fix the pulling problem when i bought it. thanks!
  2. #2 Re: Car Pulling to the Right (torque steer, transmission)
    welcome to FWD.
    if it goes straight down the highway coasting or under light gas its all good. yes it can and will pull the front end when jumping on the gas. you just need to work with it, and dont fear it.
  3. #3 Re: Car Pulling to the Right (torque steer, transmission)
    Feb 2013
    Omaha
    my car pulls to the right at ALL times. just more when i push the gas
  4. #4 Re: Car Pulling to the Right (torque steer, transmission)
    try rotating the tires then, mine did this. i had a bad alignment done and it killed my tires. rotated and re aligned at it was all good.
    also make sure the front tires are the same brand and size. mix matched brands even of the same size can cause the car to pull all the time.
  5. #5 Re: Car Pulling to the Right (torque steer, transmission)
    Nov 2011
    NY
    Weak suspension components will allow this too... Worn struts, strut mounts, bushings, etc. Check it out. I had it until I put new struts in, then it was gone.
  6. #6 Re: Car Pulling to the Right (torque steer, transmission)
    Feb 2013
    Omaha
    thanks for the input, im going to take to my own mechanic instead of the dealer who wouldnt tell me if my struts are bad, (their dime). but if i was paying for it they would have found 5 things to fix im sure
  7. #7 Re: Car Pulling to the Right (torque steer, transmission)
    you can also swap the front tires around, left to right, right to left side, if it pulls to the left, in stead of the right, you know its the tires.
  8. #8 Re: Car Pulling to the Right (torque steer, transmission)
    Feb 2013
    Omaha
    hey good idea..
  1. wheel hop/torque steer
    By Cobras 98 Prix in forum Brakes/Suspension/Chassis
    Last Post: 12-06-2011, 08:34 PM
  2. Torque Steer,Bumpy rd, and Spinning= FAIL
    By SlowM90 in forum Off Topic Discussion
    Last Post: 11-10-2009, 08:26 PM
  3. Torque Steer?
    By jdkhunter in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2009, 04:07 PM
  4. can you say torque steer?
    By 99gpse in forum Off Topic Discussion
    Last Post: 03-30-2009, 05:18 PM
  5. Replies: 12
    Last Post: 02-08-2009, 01:06 AM
