Thread: 1st Gear Transmission Problem-- Video Included.
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: 1st Gear Transmission Problem-- Video Included.
    GT Level Member wyrmscar's Avatar
    Jan 2012
    Orlando, Florida
    Quote Originally Posted by coolone View Post
    You already done more than a flush could ever... Sure all the fluid doesn't come out when you drop the pan, but a flush won't help a bit. Just sayin...
    You bring up a good point. Im a bit desperate and im thinking of anything that could help. If this tranny REALLY is dying... im honestly going to have to consider selling this thing because i dont have enough knowledge/ time/ or confidence to drop a transmission.
  2. #22 Re: 1st Gear Transmission Problem-- Video Included.
    Jan 2012
    Orlando, Florida
    Good point /: im just desperate... i dont have enough knowledge to drop a trans and dont have enough money to replace one.
  3. #23 Re: 1st Gear Transmission Problem-- Video Included.
    Dec 2012
    Where 4T65E's were born
    There's definitely slipping going on, at first anyway. At 2:11 you took it up to 3,000 RPM from a dead stop, right? That's really impossible until you start moving. Anybody can try this, from a dead stop, give it half throttle, or more but don't allow the wheels to slip. See how high you can get the RPM's to go before you start moving. I can't get any higher than 2,500 to start.
    Notice it stops right at 2,500, and climbs as I gain speed. That is normal operation. I also have a brake light on just like him, so it's the same exact conditions
    Sold.
  4. #24 Re: 1st Gear Transmission Problem-- Video Included.
    Jan 2012
    Orlando, Florida
    In daily driving it the way it is within the last week... I have had it once rev to about 4k for like 3 seconds before it would start moving but then after it drops back down to around 2500 it catches up to itself. As a note... this doesnt happen at all when starting with the gear shifter in 1 instead of d.
  5. #25 Re: 1st Gear Transmission Problem-- Video Included.
    SE Level Member bobeebob's Avatar
    chicago
    Hook up a gauge and check the line pressure. My transmission had similar problems and it turned out to be a worn input clutch piston.
  6. #26 Re: 1st Gear Transmission Problem-- Video Included.
    Jan 2012
    Orlando, Florida
    Quote Originally Posted by bobeebob View Post
    Second person to say so...Im really leaning toward this conclusion.
  7. #27 Re: 1st Gear Transmission Problem-- Video Included.
    Take a read through the swap tranmission thread in the How to section (Search my username and the word "Ea sy" without the space.
    There aren't any special tools needed that you probably can't borrow.
    Jackstands
    13mm
    10mm
    8mm
    15mm
    18mm
    34-36mm (free loaner tools for doing axles)
    3-4foot piece of 4x4
    Chain
    Jack
    That's about all you need to swap a transmission. If you read through the procedure a few times.. you'll swap it faster than most shops.
  8. #28 Re: 1st Gear Transmission Problem-- Video Included.
    Jan 2012
    Orlando, Florida
    Well ****...I was hoping it wouldnt come down to this -___-
  1. Key fob problem (video included)
    By raverockstar in forum General Grand Prix Discussion
    Last Post: 02-12-2013, 12:15 AM
  2. Bad outer tie rod end? Video link included
    By LoneGunman in forum Brakes/Suspension/Chassis
    Last Post: 09-25-2011, 11:09 PM
  3. Replies: 12
    Last Post: 10-16-2010, 08:09 AM
  4. Need Help; Several systems problems at startup. Video included.
    By tjslosson in forum General Tech Discussion
    Last Post: 09-29-2009, 08:04 AM
  5. Old '5th Gear' Video Clip
    Last Post: 11-14-2008, 10:10 PM
