Thread: 5th Bad Axle in less than 6 months . . .
Results 1 to 7 of 7
  1. #1 5th Bad Axle in less than 6 months . . .
    GT Level Member fisher580's Avatar
    Jan 2012
    Dyersville, Iowa
    Last fall I had both axles go bad with in a week so I had both replaced, then the passanger one tore the boot off and from the looks I think it twisted the inner bearing/universal (whatever the thing is called) and the driver side started shaking again. So I replaced them both and they worked fine until tonight I noticed the passanger boot ripped off again (on the inner side) so I checked and nothing is catching it to tear it. The axle doesn't shake or make noise so I didn't notice until I had a flashlight looking at random stuff and noticed it, and that its completely dry, well theres grease everywhere but my axle LOL. Any input on what could cause this and what a good replacement axle is. also if it matters last fall during the time my axles kept going out I went through both front wheel hubs twice and a third time on the passanger side.
    2001 Grand Prix GTP Coupe - Black-SOLD
    -SOLD
    2006 Grand Prix GXP - That Purplish dark red color
    -FWI, DiabloSport Trinity, and Trans. Cooler - - 6.8 @ 208 mph LOL
  2. #2 Re: 5th Bad Axle in less than 6 months . . .
    I would check your motor mounts and make sure the motor isnt moving around and causing the axle to rub on something while going over bumps etc etc.
  3. #3 Re: 5th Bad Axle in less than 6 months . . .
    Jan 2012
    Dyersville, Iowa
    My mounts are about shot, well actually im glad you mentioned that because it the pass. side mount that's the worst, ill check later tonight or 2maro. im willing to bet you just figured it out for me
    -SOLD
  4. #4 Re: 5th Bad Axle in less than 6 months . . .
    Kansas
    Are they the inner or outer boots that tear? Or is it just random?
    Reason I say is your alignment could be jacked to no end. But that should be noticeable to most.
  5. #5 Re: 5th Bad Axle in less than 6 months . . .
    Jan 2012
    Dyersville, Iowa
    inner, only the passenger side tore, the driver just went bad twice (probably from my driving) but under more investigating today Im going to go with mounts. I noticed the motor does sit towards the rear slightly causing my down pipe clamp to hit a brake line which it never did before, and from looking at the tore boot some more I can tell it must have been hitting the subframe/control arm being the metal is shiny. so new mounts for now I guess, and I checked the axle seems perfect so I might just pack in some grease and throw on a new boot and hope for the best. how big of a job is replacing the engine mount and tranny mount?
    -SOLD
  6. #6 Re: 5th Bad Axle in less than 6 months . . .
    Nov 2012
    Madison
    http://www.grandprixforums.net/insta...ers-31503.html
    Has pictures and it has the spacers you can ignore
  7. #7 Re: 5th Bad Axle in less than 6 months . . .
    Jan 2012
    Dyersville, Iowa
    just ordered the solid mounts for tranny and engine and the upper poly inserts for both ends of dog bone. once I get them in then ill throw in another new axle unless I can repack this one
    -SOLD
  1. MAF going bad after just 8 months??
    By thegipper in forum General Tech Discussion
    Last Post: 11-02-2012, 12:15 PM
  2. 3 CVs in 2 Months?
    By Kasey in forum General Tech Discussion
    Last Post: 06-03-2011, 09:56 PM
  3. Bad 3 Months
    By EJOUIE in forum The Rant Forum
    Last Post: 06-05-2010, 12:42 AM
  4. storing car for 6 months.
    By IrishNation24 in forum General Tech Discussion
    Last Post: 05-29-2009, 11:13 AM
  5. What to Do? Old Gas - Car Sat for 18 Months
    By TommyGloves in forum General Tech Discussion
    Last Post: 05-21-2008, 07:17 PM
