so my trans line is leaking at the rad and im a cheap bastard
anyway, looking at it it looks like i need a new line to the rad, as its rusty about an inch before the bottom fitting and wet with fluid around there. So im thinking this is a perfect excuse to upgrade to an aux. cooler, just buy the cooler, cut the lines and bypass the rad cooler?. Is this a good idea? I live in southern ontario canada...i know alot of people on the internet opt for bypassing the rad so the trans doesn't get up to that 180 degree temp the antifreeze runs at, but in the winter will the transmission be too cold? I dont drive the car hard and i tend to let the engine warm up a fair bit before i drive the car on the cold days, so should i bypass the rad cooler and go with a small cooler?
thanks in advance...
