Thread: What happens if you keep driving the car with a bad PCS on the transmission?
Results 1 to 8 of 8
  1. #1 What happens if you keep driving the car with a bad PCS on the transmission?
    Feb 2013
    Washington
    Our GTP was making the loud humming whining I mean like the supercharger sound and rough shifting, looked like classic pressure control solenoid. I told my family but people still drove it anyway without fixing it, and now it always whines when driving it sound like it gonna explode almost, but it never does. Not sure if overdrive is working.
    Just curious, did it ruin the transmission or is it still just a matter of switching a PCS or valve body?
  2. #2 Re: What happens if you keep driving the car with a bad PCS on the transmission?
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Did you at least check the fluid level? If it's whining, it might be low on fluid / pump is starving.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  3. #3 Re: What happens if you keep driving the car with a bad PCS on the transmission?
    Whining isn't a typical symptom from what I've heard for a PCS. It's either the trans having trouble pulling fluid due to it being low or the filter clogged, or it's the stator bearing.
  4. #4 Re: What happens if you keep driving the car with a bad PCS on the transmission?
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    I'm going with stator bearing as my guess.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  5. #5 Re: What happens if you keep driving the car with a bad PCS on the transmission?
    Feb 2013
    Washington
    Thank you everyone for your opinions. I will check the fluid and report back.
    I have never heard of a starter bearing, except in the starter which is only used just to start the car. I will look it up....
  6. #6 Re: What happens if you keep driving the car with a bad PCS on the transmission?
    Pennsylvania, USA
    Stator and starter are different.
  7. #7 Re: What happens if you keep driving the car with a bad PCS on the transmission?
    The stator bearing in the trans is the main bearing that the input shaft goes through. The stator support (outer section of it) is where the TC is held up as it puts power to the input shaft. Unfortunately you aren't changing that w/o disassembling and likely rebuilding the rest of the trans.
    A fluid based whining, say from a clogging filter, loosely fitting filter (in the collar) or low fluid it much easier to fix. You can do all of them with a simple transmission service of filter, collar and or just fluid.
  8. #8 Re: What happens if you keep driving the car with a bad PCS on the transmission?
    Jul 2010
    Coquitlam,BC,Canada
    I have a slight wine, believed to be coming from the PCS. I installed a shift kit about two years ago, and all is good. The wine is still there, but transmission performance hasn't changed (that I can tell).
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Car bobbing up and down when driving
    By GTLGDP in forum General Tech Discussion
    Last Post: 10-18-2012, 05:04 PM
  2. When your driving...
    By jer206 in forum General Grand Prix Discussion
    Last Post: 04-28-2012, 10:40 PM
  3. Over Driving the SC
    By GreyGhost in forum General Tech Discussion
    Last Post: 01-30-2011, 07:32 PM
  4. This is driving skill!
    By Abrasive in forum Off Topic Discussion
    Last Post: 11-14-2008, 11:02 PM
  5. while driving, BOC!
    By fst in forum The Rant Forum
    Last Post: 02-04-2008, 10:47 AM
