Thread: 1998 Trans in 2001 car
Results 1 to 2 of 2
  1. #1 1998 Trans in 2001 car
    SE Level Member oldsman105's Avatar
    Queens, New York
    Will the transmisson from 1998 Regal work in a 2001 bonneville SSEI. I know that the regal trans has the webbing on the back to work in a G-body platform, but are there any other issues?
    Thanks in advance.
    2002 Pontiac Bonneville SSEi
    Gen V with 3.6 pulley , 1.9 Rockers, L76 Springs, N* TB, 40lb injectors, Power log, 3" Down-pipe
  2. #2 Re: 1998 Trans in 2001 car
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    It wont work without problems. All 00+ Bonneville transmissions used an internal range switch, the Grand Prixs up until 02 used an external switch. The cooler line fittings on the trans case are also different and a 98 case wont work with the 01 style fittings.
  1. 1998 GTP TPS problem
    By kw_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2013, 05:43 PM
  2. Need a 1998 Buick Century Bin File
    By buickman104 in forum PCM Tuning
    Last Post: 08-19-2008, 10:22 PM
  3. worth it to buy? 1998 z24 auto convertibe
    By fst in forum Off Topic Discussion
    Last Post: 01-31-2008, 03:12 PM
