Thread: Trans rebuild after metal shavings, what to do about the converter?
Results 1 to 11 of 11
  1. #1 Trans rebuild after metal shavings, what to do about the converter?
    Jan 2012
    N/A
    Hey guys, Getting my tranny rebuilt finally
    Got it pulled out of the car , had metal shavings in fluid, lost 3rd, but my buddy corey said im gonna have to get the Stall rebuilt, or flushed, or something to that extent? im running a 3250 with my turbo setup.
    What should i do? The converter has 3000 miles on it.
  2. #2 Re: Trans rebuild after metal shavings, what to do about the converter?
    Ohio
    id look for a new one
  3. #3 Re: Trans rebuild after metal shavings, what to do about the converter?
    Jan 2012
    N/A
    It just sucks because its almost brand new lol
  4. #4 Re: Trans rebuild after metal shavings, what to do about the converter?
    Ohio
    **** happens :/
    I put a new trans in my car...three days later, threw a rod.
  5. #5 Re: Trans rebuild after metal shavings, what to do about the converter?
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    Quote Originally Posted by 99PGPGT View Post
    **** happens :/
    i bet that hurt
  6. #6 Re: Trans rebuild after metal shavings, what to do about the converter?
    never reuse a torque converter that was on a blown tranny. it will kill the new tranny.
    buy a new one. its the safest bet.
  7. #7 Re: Trans rebuild after metal shavings, what to do about the converter?
    Jan 2012
    N/A
    And another question, Andrew Schnicke is the one going to be building my trans, he said he uses Stock GT converters in most setups, Would that mess with my setup being i had a 3250, Or what differences would there be
  8. #8 Re: Trans rebuild after metal shavings, what to do about the converter?
    Ohio
    No it will be fine.
  9. #9 Re: Trans rebuild after metal shavings, what to do about the converter?
    Jan 2012
    N/A
    Im gonna make a post for that being its a different issue
  10. #10 Re: Trans rebuild after metal shavings, what to do about the converter?
    stall speed is how high the rmp's climb to while holding the brakes and giving it gas. like to launch off the line. thus having your engine rpm's in the engines power range at launch.
    if its a just a drag car that would be fine, but for a daily driver 3200 seems high, gas mileage may suffer. stock is around 1800 or 2000 iirc.
    2500 may work out well, these engines seem to make good power at lower rpms.
  11. #11 Re: Trans rebuild after metal shavings, what to do about the converter?
    Jan 2012
    N/A
    It is my dd
  1. Part (thin, flat metal) that falls out when changing trans filter
    By grandgt01 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-18-2012, 06:23 PM
  2. replace torque converter on rebuild?
    By blown98gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-16-2011, 11:41 PM
  3. Trans rebuild
    By Logan541 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-13-2011, 04:06 PM
  4. Can I rebuild my Trans????
    By timboku in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-17-2010, 01:55 PM
  5. Metal Shavings
    By GTPluv in forum Off Topic Discussion
    Last Post: 04-02-2008, 11:53 AM
