Thread: 03+ 4t65 transmission
Results 1 to 9 of 9
  1. #1 03+ 4t65 transmission
    Dec 2012
    troll land
    will a 03+ 4t65 work with a 98-02 pcm and harness?
  2. #2 Re: 03+ 4t65 transmission
    Omaha, NE
    No.
    I don't remember all the year differences to explain it in detail, but I think 98-00 is different from 01-02 and 03+ or something like that.
  3. #3 Re: 03+ 4t65 transmission
    Dec 2012
    troll land
    reason i was asking was cause i herd they were stronger
  4. #4 Re: 03+ 4t65 transmission
    Omaha, NE
    I've broke one in an 04 and one in an 05. The 05 was bone stock, never abused.
    If you want a stronger trans, you need to get a built one, or build one yourself. TripleEdgePerformance is a good place to start.
  5. #5 Re: 03+ 4t65 transmission
    Dec 2012
    troll land
    k kool
  6. #6 Re: 03+ 4t65 transmission
    97-02 are the same, the trans line connectors are different after 00+ and maybe a minor change in a PCM file for it.
    03+ transmission have a different valve body and a hardend 4th gear. The PCM controls the trans different aswell.
  7. #7 Re: 03+ 4t65 transmission
    Dec 2012
    troll land
    thankx man
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    You can use an 03 trans in a 98-02 car of you use an 03 PCM / trans cal and the trans range switch off a 98-02 trans. No wiring changes needed.
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  9. #9 Re: 03+ 4t65 transmission
    Dec 2012
    troll land
    kool thanx
  1. 3.29s into a 4T65-HD?
    By Raysefanatic in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-14-2011, 12:27 PM
  2. 4T60-e to 4T65-e in 97 GP GT
    By GPdude97 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-17-2009, 02:10 AM
  3. Prices for used 4t65-hd
    By robahr24 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-26-2008, 08:16 PM
  4. 4t60 or 4t65
    By merked in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-21-2008, 04:25 PM
