Thread: Wont Shift out of First Gear
Results 1 to 5 of 5
  1. #1 Wont Shift out of First Gear
    Apr 2012
    canada
    Hey guys,
    I got a question that hopefully will spark some ideas/solutions on what may be wrong and what I can try to fix on my car.
    Just today i was driving my car home from work and all of a sudden my car would not shift out of first gear, it will rev up, but not shift at all. It drives fine in first and seems to shift smooth into N and R.
    Any idea's or thought would be great
    thanks
    2003 GTP
  2. #2 Re: Wont Shift out of First Gear
    How is the engine running?
  3. #3 Re: Wont Shift out of First Gear
    Apr 2012
    canada
    Engine runs perfect no problems
  4. #4 Re: Wont Shift out of First Gear
    Hmmmm
    The shifting is largely effected by the tps, maf and map sensors. You can run fine and have a bad map. Worth checking out. Beyond that, it likely isn't an internal issue from what I've experienced. A forward band would have taken out all forward movement unless you put it in manual 1 or 2.
  5. #5 Re: Wont Shift out of First Gear
    Apr 2012
    canada
    Thanks for the info, the engine light comes on but is showing up a different code that does not relate to the transmission. Would the map sensor show up on the computer? and where abouts is it located on the car?
    Thanks!!!
  1. tranny wont shift into 3rd gear. please help where is my 3rd gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-20-2012, 11:49 AM
  2. Grand prix wont shift out of first gear until transmition is warmed up.
    By superluk9000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-11-2012, 07:17 AM
  3. 2nd gear to 4th gear shift
    By 98grannyprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-17-2011, 01:03 AM
  4. 1st gear wont engage
    By dmcglynn in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-09-2010, 02:30 PM
  5. Wont shift into 4th gear
    By youngmcse in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-08-2009, 05:23 AM
