so i finally took my car to a trans shop,the problem i had was getting unbearable.The shop i took it to is owner operated and the guy has been doin trans work for over 20 yrs...to the point,i just wanna get ur 2 cents before i have anything done...basically he said the p1811 code means nothing to him...i dunno if u remember my problem or not ive spoked to u on here several times about what it was doing.some days on a cold start i put it in reverse then drive and it lags really bad,rpms dont jump too high.but it feels like it doesnt wanna go.i let off gas for a second or two then its fine...then after around town driving for any length of time,it shifts hard into almost all gears also sometimes when i get on the gas a lil bit thers a noticeable vibration that i feel in the gas pedal.my fluid isnt burnt and theres no metal in pan.The owner of the shop says hes 75% sure its the epc solenoid...said he he will swap out with a borg warner solenoid for 275.00...in ur opinion do u think this will fix my problem? also u had emailed me saying that it could b input shaft is the reason im getting lag on a cold start...dont think im doubting u,but this guy said i would def have metal in pan if it was input shaft,is this true?...im clueless when it comes to transmissions.
