Thread: What is the difference in an 03 Trans and will it "bolt on" an 01 GT
Results 1 to 4 of 4
  1. #1 What is the difference in an 03 Trans and will it "bolt on" an 01 GT
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    So my 4th gear is gone (has been for some time) and the trans is starting to slip so i figured it time for a new one. I found an 03 GT in the junkyard thought maybe that would be a good tranny to rebuild since it already has a hardened 4th clutch hub. I remeber someone I think it was FFDP saying that the 03 trans are slightly differnt but what is different besides the 4th clutch hub? And can i still swap it into an 01 GT and just bolt it in and then plug and play? I don't want to have to splice any wires or modify anything.
    Also if anybody knows a good place to get a cheap rebuild kit (its just a DD) that would be great too
    Thanks
    I went NA when a whore left -$300 in my bank account.
  2. #2 Re: What is the difference in an 03 Trans and will it "bolt on" an 01 GT
    GrandPrix Junkie
    Mar 2012
    NC
    You have to change the valve body IIRC. Gearing should be the same though.
  3. #3 Re: What is the difference in an 03 Trans and will it "bolt on" an 01 GT
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    To use an 03+ 4T65E trans in an 02 and earlier car you have to use a 2003 pcm. All 2003+ 4T65E transmissions are electrically different and are not plug and play so you must use a correct matching pcm and 2003 was the only year of the old body style. It is best to use the correct year so you dont have the headache of swapping this especially if you dont have the ability to reprogram the pcm.
  4. #4 Re: What is the difference in an 03 Trans and will it "bolt on" an 01 GT
    You could go see that guy for a trans ^^^
  1. Replies: 7
    Last Post: 04-19-2012, 12:44 AM
  2. 2013 "Pontiac Trans Am"
    By Hippo Machine in forum Off Topic Discussion
    Last Post: 08-29-2011, 10:05 PM
  3. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
  4. 4t65e hd TRANS REBUILD ! " with pics "
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2010, 09:38 PM
