Thread: Mileage Failure
Results 1 to 20 of 27
  1. #1 Mileage Failure
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Probably a thread about this already but I'd be curious to see who can chime in with transmission mileage at failure..
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  2. #2 Re: Mileage Failure
    Yoga city
    all random numbers my friend
    Oct 2011
    MI
    Yeah I was just curious my CompG has 130k and is just fine, shifts seem slow but I just had the battery pulled for a week while the engine was pulled. Doesn't seem like a slip that's for sure.
    But I had an 04 GTP that has 240k+ and is still being driven around with an original transmission.
    Anyways I was just curious to hear mileage shout outs
  4. #4 Re: Mileage Failure
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    I had 170k before 4th gear went out
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
  5. #5 Re: Mileage Failure
    my 98 regal trans went out at 218,000. lost 3 rd gear, o/d still worked, and the 1- 2 shift was still tight.
  6. #6 Re: Mileage Failure
    Pennsylvania
    Quote Originally Posted by rperry435 View Post
    It takes the computer a few miles to relearn proper shifting when you disconnect the battery that long.
  7. #7 Re: Mileage Failure
    Yeah..what he said!
    I haven't failed one yet that wasn't abuse/power related and all those were too fresh to count.
    Bonneville was a little slopped at 176K when I had it built up.
    Regal had 186K when I pulled out it's trans based on a bad coil pack feeling like a slip at times.
    Other cars..I've bought cars with 180K+ and driven..then sold.
  8. #8 Re: Mileage Failure
    Sep 2012
    St Louis Missouri
    Anyone else want to add? im curious. And how much less would a tranny last on a 3.4 setup driven relatively granny except for the occasional floorage.
  9. #9 Re: Mileage Failure
    Lets put it this way, its going to work all the way up the point where it breaks.
    I live here. DirtDog's Avatar
    Jun 2012
    Woah...that's science sh*t right there
    Sent from my DROID RAZR using Tapatalk 2
  11. #11 Re: Mileage Failure
    Waukesha, WI
    180k when the GTs lost foward band.
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  12. #12 Re: Mileage Failure
    Sep 2012
    St Louis Missouri
    Redline what mods are on your gtp?
  13. #13 Re: Mileage Failure
    Antioch, IL
    previous owner had it rebuilt at 140k. Cars got 219 right now.
    2009 Challenger SRT8
    Expert at being gay.
  14. #14 Re: Mileage Failure
    Waukesha, WI
    headers, tune, cai, 3.4, rockers. that trans is still holding up at 130k
    i had a bone stock GT also that lost forward band at 180k. had a rough life though
    RayRay
    92 Turbo miata
    02 lexus is300
  15. #15 Re: Mileage Failure
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    My trans failed twice.
    Once with the previous owner, unsure about mileage.
    Then again it failed on me at 145k. (But that was my fault, i flushed the trans. Dont do that, learn from my mistake).
    GTX Level Member crbquist's Avatar
    Massachusetts
    Cam, gen 5, supporting mods, etc. and my original trans doesn't skip a beat at 112k miles.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  17. #17 Re: Mileage Failure
    Sep 2012
    St Louis Missouri
    My trans has 128k on it but Im not sure if iwant to mod it or not. Im trying to make this car last 4 or 5 years. My last car i had a year and a half and doing almost all city driving i put like 18k on it.
    If you consider beating on it flooring it and what not, I dont do that often at all. Only every once in a while when someone wants to race. Even getting on the highway i usually never go wot. And other than that i drive city a lot so i often try to save mpg by coasting, or quickly getting up to speed and then cruising/coasting...
  18. #18 Re: Mileage Failure
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    Had the car for about a year and a half and at 136,000 she started to slip. Got it rebuilt and at 155,651 shes doing great (thank goodness)
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  19. #19 Re: Mileage Failure
    Sep 2012
    St Louis Missouri
    Quote Originally Posted by burgundybullet View Post
    Was it modded or beat on until that 136k point?
  20. #20 Re: Mileage Failure
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    bought the car from a guy at 104k.. he had intense pcm c.a.i. 3.4 pulley... day after i bought it trans went
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  1. 97-03 NA L36 UIM Failure
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 09-15-2015, 07:27 AM
  2. jpg. failure
    By hodge in forum Forum Bugs/Suggestions
    Last Post: 04-04-2011, 08:11 PM
  3. Failure
    By mechguy in forum Off Topic Discussion
    Last Post: 03-25-2011, 01:39 AM
  4. TB Gasket Failure?
    By ChrisJ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2010, 05:49 PM
  5. possible failure yet again??
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-24-2008, 08:40 PM
