Thread: Gear Change Question?
Results 1 to 20 of 23
  1. #1 Gear Change Question?
    Oct 2011
    Puyallup WA
    Hey guys I have a 04 Comp G with the 3.29 gears would like to switch to the 2.93 gears to help increase my MPG's...other then the sprockets would I be able to tune for the diff gears and tapshift still work normally? People switch to 3.29's all the time but they aren't usually Tapshift cars. Anyone have thoughts on this not working?
    08 G8 GT - exhaust Tune
  2. #2 Re: Gear Change Question?
    Sounds like a question Dave at TEP might know more about.
    Otherwise adding timing to the cruise tables and driving 65 instead of 70+ will help alot.
  3. #3 Re: Gear Change Question?
    Oct 2011
    Puyallup WA
    Yeah I already have added timing in the cruise tables best I have done was 26mpg...my trans is getting weak so when I do a rebuild was hoping to change the gears for a couple more mpg
  4. #4 Re: Gear Change Question?
    Pennsylvania
    Thought dudes were saying they got better mpg when they switched to 3.29's anyway.
  5. #5 Re: Gear Change Question?
    Oct 2011
    Puyallup WA
    Quote Originally Posted by SlowNA06 View Post
    Best I get is around 26mpg highway...my buddy with 2.93 gears gets 28-30
  6. #6 Re: Gear Change Question?
    I would do it the reverse of what I posted that Dave said about 3.29's.
    Start with the stock 3.29 Comp Table, I'd expect it says 3.69 gears. Plug in 3.29 and the tire size then commit with the auto scale on. Poof...
  7. #7 Re: Gear Change Question?
    Oct 2011
    Puyallup WA
    I just pulled my stock Comp Table and it still says 3.29 for calculated gear....so would I have to plugin 2.93 after the gear change? This may be more of a pain then its worth
  8. #8 Re: Gear Change Question?
    Portland Oregon
    Comp G tables have the correct sprocket ratio of 1:1 and 3.29 FDR. Should just be able to do the opposite of what the 2.93 guys do and just put in 2.93 and click commit.
  9. #9 Re: Gear Change Question?
    Oct 2011
    Puyallup WA
    Did you notice a mpg drop when you put 3.29's in your regal? Wondering if its really worth the hassle...maybe I just need more cruise timing
  10. #10 Re: Gear Change Question?
    Im curious as to what your tables look like, 26 is pretty low for highway mpgs.
  11. #11 Re: Gear Change Question?
    Oct 2011
    Puyallup WA
    Timing ranges from 35 to 45 degrees from the 1st column to 0.36 cyl air mass....rpm range is 1200 to 2400...as I remember last time I went on the freeway was seeing High 30's Timing...was told to not go over 40
  12. #12 Re: Gear Change Question?
    Pennsylvania
    Maybe you're burning coolant instead of a healthy AFR. Got an aluminum LIM?
  13. #13 Re: Gear Change Question?
    Oct 2011
    Puyallup WA
    That is a possibility...I'm in the middle of changing to alum ones waiting for the parts to show up but yes the plastic ones looked like the where starting to come apart
  14. #14 Re: Gear Change Question?
    There are definately trans tables we can't see that effect things. If you did it, you might be able to get away with correcting the sprocket ratio to 1.21
  15. #15 Re: Gear Change Question?
    Oct 2011
    Puyallup WA
    Thanx for your input bill! At this point I think ill put my gaskets back in do some more tuning for freeway and see if it helps at all...if not then ill try the 2.93's
  16. #16 Re: Gear Change Question?
    Pennsylvania
    Stray coolant will definitely lower your mileage.
  17. #17 Re: Gear Change Question?
    Oct 2011
    Puyallup WA
    Ok we'll hopefully that is the issue...what mpg do people usually get with 3.29's
  18. #18 Re: Gear Change Question?
    GT Level Member WolvesSoulZ's Avatar
    Québec
    With my Comp-G last time I did a little road trip I had 28-30mpg the whole trip(About 300 miles with about 100 of hills.). Gets about 20-24mpg city driving with a careful foot.
    My L67 + 3.29 GT gets about 26-28mpg, but it's heavier. (Hitch, two subs, all my tools were often in my trunk.)
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  19. #19 Re: Gear Change Question?
    Oct 2011
    Puyallup WA
    Yeah mine gets 24 to 26 highway and about 16 to 19 in town
  20. #20 Re: Gear Change Question?
    Portland Oregon
    That's about right. My regal did about the same after I 3.29 swapped when I got the trans.
  1. 2.93 to 3.29 gear change tuning HPtuners
    By OH4CompG in forum PCM Tuning
    Last Post: 05-12-2016, 11:00 AM
  2. Gear Ratio Change
    By 01GrandPrixTURBOGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-28-2012, 02:12 PM
  3. Transmission Fluid - 173K..To change or not to change, that is the question
    By 99XC600 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2012, 10:03 PM
  4. Gear change
    By dengnath in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-17-2011, 02:53 PM
  5. gear ratio change need pcm to be corrected
    By 2000 Black 2dr in forum PCM Tuning
    Last Post: 10-19-2010, 07:48 PM
