Hello can anyone point me to where the Speed sensor is located? also which brand is best recommended?
ok so if I am reading this correctly that is right above where the cv shafts connect to the transmission? Also how easy is it to get to the sensor.(i feel too lazy to go look for myself at the moment lol)
It's on the passenger side. Not to bad to get at through the fender well
If the car has never been messed with, there will be a wiring harness taped to a plastic piece that sits on the stud of the VSS sensor bolt. Lift that up and off (it's really that easy), then using a 10mm remove the bolt and the sensor/holder will wiggle and pull right out.
Expect some metal sludge on it, it is a magnet.
