Thread: Where is the 2nd clutch stack?
Results 1 to 4 of 4
  1. #1 Where is the 2nd clutch stack?
    SE Level Member Aeroheadcww's Avatar
    Williamsburg, Ky
    I am going to replace my valve body and I was considering upgrading the 2nd stack to the Triple Edge set with thicker steels. I was wanting to know if the 2nd stack is underneath of the channel plate or if it is harder to get to than that. I know the 4th clutches are right there, thanks to bb's write up on the hub shaft, but I don't know about the 2nd clutches.
    _____________________________________________
    '05 CompG - 3.6 Pulley, ZZP PCM, K&N drop in, Customized SD Headers, TEP Street/Strip tranny, ZZP STBs, ZZP Coilovers, GXP front brakes
  2. #2 Re: Where is the 2nd clutch stack?
    Remove side cover and pull the insides out and in there is the 2nd clutch packs and everything else.
  3. #3 Re: Where is the 2nd clutch stack?
    Williamsburg, Ky
    "pulling the insides out" is what I was trying to avoid
  4. #4 Re: Where is the 2nd clutch stack?
    Portland Oregon
    Second clutch stack is under the driven sprocket support beneath the channel plate. It's the first drum you take out.
  1. How does the GTP stack up to cars nowadays?
    By SF9777 in forum General Grand Prix Discussion
    Last Post: 10-30-2012, 08:46 PM
  2. Short Stack Intercooler [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-30-2012, 04:20 PM
  3. OBX and DPT cheap ebay headers? How they stack up vs. ZZP?
    By funky4stringed in forum General Tech Discussion
    Last Post: 08-01-2010, 07:22 AM
  4. Short Stack Intercooler ????
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 06-22-2010, 12:24 PM
  5. zzp short stack ic
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2008, 03:53 AM
