Thread: Pennzoil Dexron VI
Results 1 to 20 of 24
  1. #1 Pennzoil Dexron VI
    Aug 2008
    Long Island, New York
    Is Pennzoil Dexron VI good? its the only dexron VI oil the store by me had
  2. #2 Re: Pennzoil Dexron VI
    Aug 2008
    ...wow i mean tranny fluid... not oil
  3. #3 Re: Pennzoil Dexron VI
    GXP Level Member ryangtp89's Avatar
    Maine
    Well i hope it is, cause i just sent my car off to get my new tep tranny installed and i bought dextron VI, i bought 2 gallons of it from zzp and its the gm car care brand and then i bought the rest from vip, its the penzoil dextron VI it should be the same stuff and i should be ok.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  4. #4 Re: Pennzoil Dexron VI
    PA
    Quote Originally Posted by ryangtp89 View Post
    Penzoil Dex VI is fine. The Dexron VI rating will give you a lot more benefits over the old Dex III stuff. Overall, you should be fine.
    2001 GSE
  5. #5 Re: Pennzoil Dexron VI
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    i would use DEX VI but i would stay away from Penzoil
  6. #6 Re: Pennzoil Dexron VI
    Maine
    ^^^ Why it's the same stuff dextron VI is the same as penzoil Dextron VI. Maybe i'm getting you wrong.
  7. #7 Re: Pennzoil Dexron VI
    St. Louis
    right but i have heard rumors that penzoil also adds special additives to keep you from switching back... i am not sure how true that is i use dextron VI i just don't use the dextron that penzoil makes
  8. #8 Re: Pennzoil Dexron VI
    Maine
    Ohh i c, i had to buy the rest from vip so i had to get penzoil instead of getting gm car care because i didnt want to buy it by the gallon from zzp and have to pay for the shipping.
  9. #9 Re: Pennzoil Dexron VI
    PA
    Quote Originally Posted by stlmo_gtp View Post
    So you have no proof? I heard rumors that GM was switching all their car lines to V8 RWD. But it is just a rumor. And worth nothing.
    Dexron VI is a specification that demands the fluid properties and makeup of all fluids that have are called that. Some other fluids, such as Amsoil will advertise that they meet the performance specifications of Dexron VI because the composition is not the same as other Dexron VI fluids. But in order for a tranny fluid to be identified as a Dexron VI fluid, it needs to meet strict guidelines from General Motors Corp that specify performance standards as well as compositional standards. For this reason, I can guarantee that Penzoil does nothing of the sort. One Dexron VI fluid should be very similar in performance and chemical makeup as the next. Valvoline Dexron VI is a full synthetic instead of a semi-synthetic, but still approved by GM as only how the base stock is composed is changed. The rest of the ingredients are monitored very closely.
    FWIW, any GM dealer service shop will carry and sell GM Dexron VI fluid. You don't have to buy it from ZZP everytime. But again, not much difference from GM fluid, to Penzoil, to Castrol, to Valvoline. All are Dexron VI and all will work fine, even mixed together.
    2001 GSE
  10. #10 Re: Pennzoil Dexron VI
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    Quote Originally Posted by Zef_66 View Post
    okay, if this thinking is true, as I assume it is, then I could save myself ~$2 a quart by buying WalMart brand Dex VI fluid and be okay? I'm wanting to do a filter change and fluid swap (2 or 3 times to get the old crap out -- ref Bob is the Oil Guy calculator) and would rather not spend the extra money for the name on a label.
    thots?
  11. #11 Re: Pennzoil Dexron VI
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    You should be fine. The WalMart brand is probably made by one of the major brands and sold under the WalMart label. If you look on the back, it may even tell you by whom it's manufactured.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  12. #12 Re: Pennzoil Dexron VI
    PA
    Quote Originally Posted by Vegas~Blown View Post
    thots?
    I wouldn't have any problems using wal-mart fluid on a daily driver. The Dexron VI fluid is leaps and bounds better than the Dexron III fluid. While not the best fluid availble, the Walmart brand should be fine, as long as you are not hard on your car.
    2001 GSE
  13. #13 Re: Pennzoil Dexron VI
    SE Level Member pontiacman22's Avatar
    Oct 2008
    Miami,FL
    Define "HARD." lol
  14. #14 Re: Pennzoil Dexron VI
    PA
    Quote Originally Posted by pontiacman22 View Post
    Define "HARD." lol
    I drive my car as a daily driver. It gets me to and from work. I learned a long time ago that if you beat on a vehicle that you depend on, it will eventually let you down when you least expect it to happen. Thus, I drive my car gingerly, take care of it, and it treats me fine in return. While I take it to the track from time to time, I do it sensibly. I don't beat on it or drive it hard. I save that for the vehicles I don't have to depend on everyday.
    So, if you do beat on your car and drive it hard, then you are going to want to use top of the time stuff to help keep it from breaking down and I would not want to use Wal-Mart or any other cheap tranny fluid. I would be looking at +$10/quart stuff like Redline, Royal Purple, or Amsoil.
    2001 GSE
  15. #15 Re: Pennzoil Dexron VI
    GT Level Member 04 GTP COMP G's Avatar
    Jul 2008
    Saskatchewan, Canada
    Has anyone used this Max ATF is a synthetic, high-performance, automatic transmission fluid. It's by Royal Purple. I'm thinking of puttinh it in my tranny.
    LIVE LIFE FULL THROTTLE!!
  16. #16 Re: Pennzoil Dexron VI
    Royal purple will work fine, but its a waste...they all have to meet the same spec and they cant "exceed" that spec because essentially it will make the fluid too slippery and cause the trans to slip. So weather its cheap wal-mart oil or expensive novelty brands like royal purple/amsoil etc.. there not going to be a hell of a lot of difference if any (other than the fancy label)
  17. #17 Re: Pennzoil Dexron VI
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by _nick_ View Post
    Wrong. It's not the fact that the more trusted name brands can't outdo the cheapy stuff becuase it'd be to 'slippy'. It's the fact that the cheap crap is made cheap and will break down a lot quicker than the good stuff and does'nt reduce friction as much as the 'novelty' brand which it turn creates more heat which makes the fluid break down faster. The cheap part store brand, Wal Mart brand junk is not even on the same level as B&M, Castrol, or something of that sort.
  18. #18 Re: Pennzoil Dexron VI
    Barksdale AFB, LA
    Exceeding specs doesn't mean it is more slippery. It means that it lasts longer against shearing and breakdown in high heat and load conditions. More protection for your internals.
    2009 Subaru Impreza WRX STI
  19. #19 Re: Pennzoil Dexron VI
    The whole idea is most of the "cheap" brands are just made by the more expensive companies. A friend of mine worked for Quaker state, and their synthetic motor oil is the same as wal-marts tech 2000 synthetic oil And there's a huge price difference there. I personally cant justify paying upwards of $10/bottle for some novelty brand trans fluid or oil. I remember watching a show that tested major motor oils in a variety of categories, and some of the more expensive ones actually failed while the cheaper name brand oils preformed quite well. Your best bet is to buy regular name brand products instead of the cheapest 'house brand', and avoid over priced specialty brands that claim the world on the bottle...
  20. #20 Re: Pennzoil Dexron VI
    Banned
    Who ever said Quaker State was a good brand? It's about the most worthless you can buy. Same stuff as Pennzoil. Both worthless and no better than store brand stuff to begin with.
  1. Rough shifting, switch to Dexron VI?
    By Deezul_AwT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-20-2008, 12:20 PM
