Thread: Quick shifting (sometimes) after warmed up
Results 1 to 3 of 3
  1. #1 Quick shifting (sometimes) after warmed up
    Sep 2012
    Charlotte
    2000 Grand Prix SE 3.1 I've "inherited". From a cold start, shifting feels OK. Then at some point after being warmed up, the car goes into what I call "indy car mode", where it shifts immediately. Doesn't happen every time, but often enough. Turning off the car and letting it sit for 10 minutes seems to reset things.
    Any idea where to start? No CEL or codes being thrown that Torque can read.
  2. #2 Re: Quick shifting (sometimes) after warmed up
    St. Louis
    What kind of condition is the fluid in? Is it nice and red or brown/black? My 00 GT does this occasionally. Figure it's the PCS going bad. Your average code reader cannot scan for trans codes. Take it to a trans shop or dealer and have it scanned and see if any codes pop up.
  3. #3 Re: Quick shifting (sometimes) after warmed up
    Can Torque read P1811? That is max adapt shift. If the pcm see's something with the trans as being bad, it'll jack line pressure causing harsh shifts and this code is stored in history, but not current. Meaning, cycling the ignition would reset it, and a scanner may not find it based on having turned the car off.
  1. Grand prix wont shift out of first gear until transmition is warmed up.
    By superluk9000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-11-2012, 07:17 AM
  2. 2 to 3 tranny shifting & WOT shifting problems
    By josh in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-21-2010, 08:52 PM
  3. Trans not shifting after warmed up
    By pos99se in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-04-2009, 11:29 PM
  4. Car takes two or three tries to start.. once warmed up starts fine.. Any info?
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2009, 03:42 PM
  5. What temp should a 2004 GTP run at when warmed up?
    By Edmonchuck in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2008, 11:34 PM
