Thread: Transgo Shift Kit Install Help
Results 1 to 14 of 14
  1. #1 Transgo Shift Kit Install Help
    SE Level Member matthew911's Avatar
    Feb 2010
    I'm pretty much a noob so bear with me. I have not found instructions that I'm satisfied with since the write-up link on here isn't working. I'm looking to use the medium setting. Which colored springs have to be used on each accumulator? And if I use the optional spring for one of the accumulators, which spring is it? I'm assuming both the long and short spacer is used on each rod, long one first with the short one on top.
    I don't need pictures. Just want to make sure I put the right springs/spacers in each accumulator. Thanks for any help you can provide.
  2. #2 Re: Transgo Shift Kit Install Help
    GTP Level Member winterstorm's Avatar
    Jun 2012
    Connecticut
    im not familiar with the transgo shift kit so im not sure. but what i wanna ask is why just the medium setting???? do the max setting itll be more fun!!
    2005 Grand Prix GT
    Corsa Sport Catback, Thrasher Shift Kit, Custom Open Cone Intake, Spyder Chrome CCFL Halo Projector Headlights, CG LED Tail Lights, Pioneer DEH-33HD stereo unit, Alpine SPR-60C 2 way 6 1/2's, Kicker KS 6x9's
  3. #3 Re: Transgo Shift Kit Install Help
    Feb 2010
    Haha. For a daily driver I think the medium is more than enough.
    Also, after opening the bag I realize I have two of the longer spacers, and only one of the shorter. Hopefully it's supposed to be like that.
  4. #4 Re: Transgo Shift Kit Install Help
    Jun 2012
    Connecticut
    dude i have the thrasher shift kit and i did the max/race setting its not that big a deal. mines my DD too. the harsh shifts only happen at WOT which is when you want them to happen. do the max setting!!!!
    2005 Grand Prix GT
  5. #5 Re: Transgo Shift Kit Install Help
    Feb 2010
    The tranny has a lot of miles on it, and to be honest I don't know how long it has left. I'd be more comfortable just firming up the shifts a little in the meantime until I get a new vehicle. Medium is perfect for that.
  6. #6 Re: Transgo Shift Kit Install Help
    Jun 2012
    Connecticut
    the max setting wont hurt it dude, its better for the clutch. just dont beat on it all the time
    2005 Grand Prix GT
  7. #7 Re: Transgo Shift Kit Install Help
    The trans go kit has instructions.
    And yes it only has 2 longs and 1 short.
    IIRC the 2-3 has 3 springs and uses both spacers, long and short. the 1-2 uses 2 springs and 1 long.
    The transgo kit is more of a mild shift kit and fix it kit, the thrasher kit has more than 1 setting you can pick.
  8. #8 Re: Transgo Shift Kit Install Help
    Jun 2012
    Connecticut
    so wait...you make it sound like the transgo doesnt have different settings? then what is this guy talking about haha
    2005 Grand Prix GT
  9. #9 Re: Transgo Shift Kit Install Help
    The transgo kit only has 1 setting. Its NOT a performance shift kit. Its just a normal mild shift kit to help the trans from the factory faults, its far better than the stock settings.
    If you read about the kit on triple edge performance it says it right in the text about it.
  10. #10 Re: Transgo Shift Kit Install Help
    Jun 2012
    Connecticut
    alright haha. then why is this guy saying hes using the medium setting, does he realize there only one setting? lol
    2005 Grand Prix GT
  11. #11 Re: Transgo Shift Kit Install Help
    Feb 2010
    I assumed from reading other sites that there was more than one setting. But one setting makes sense and now the instructions seem to be more clear. Thanks for the help fivefingerdeathpunch.
  12. #12 Re: Transgo Shift Kit Install Help
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    Lol I like it when u get the wot shift into second and it barks the tires...I also get it at 40 mph on the downshift lol then at 58 back into second
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  13. #13 Re: Transgo Shift Kit Install Help
    Jun 2012
    Connecticut
    do you have the thrasher or transgo?
    2005 Grand Prix GT
  14. #14 Re: Transgo Shift Kit Install Help
    Dec 2008
    Lawndale, CA
    Intense and thrasher are the kits that have adjustable settings. As stated the transgo is a mild set up. No adjustability.
    Here are the istructions for the kit
  1. Transgo Shift Kit, 1st to 2nd Slower Then Stock? Help!
    By HiLuckyB in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-04-2012, 02:19 AM
  2. Installing Transgo SK4T65E shift kit - need help with valve body removal (side case)
    By Overboost in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-31-2012, 04:54 PM
  3. transgo shift kit install Q
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-10-2012, 11:19 AM
  4. Just Ordered Transmission Cooler and TRANSGO Shift Kit (UPDATED!)
    By lattyd in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2012, 11:40 AM
  5. Thrasher vs Transgo shift kit
    By anks106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-03-2008, 10:21 PM
